Not even ethernet
Solved by Mappski,
Right click the driver, then click properties and go to the details tab. From the drop-down, select "Hardware IDs" and make a not of the 4 characters after "Ven_" and after "Dev_". After you have done this go to www.pcidatabase.com/ and type in the four "ven_" digits in the vendor search box. Once you have found the vendor, you can do a ctrl + f on the page with the other four digits and if it is listed in the database it will tell you the model of the adapter. There is normally a link to the download page for drivers...
