3.5mm audio cable with mic
Solved by Booyah1555,
V-moda sells some great cables
the boompro is a boom mic on the headphone end, and a 4 pole on the other end for smartphones and headphone mic combo ports, with a break out cable for standard ports
edit: also the most durable headphone cables I have ever used.
the 1 button "speakeasy" cable is also available. just a great cable with an inline mic but doesn't include the breakout cable. so your device needs a headphone mic combo port to function, like is found on many smartphones, ultrabooks, and other notebooks
thanks the speakeasy looks perfect. I have an adapter from some old turtle beaches (dont judge I've moved on)
