hmm
have you look at your computer power management settings in the control panel?
it called 'Power Options'
create a custom power plan and set everything to high or max
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/167929-nvidia-control-panel/#findComment-2234131
There is still no need to change it for a PC. All maximum performance option will do will force your GPU to crank itself up to the max possible clock setting, regardless of the game needs that much GPU power or not. It's like forcing your CPU to run at it's peak overclock at all times.
i7 2600K @ 4.7GHz/ASUS P8Z68-V Pro/Corsair Vengeance LP 2x4GB @ 1600MHz/EVGA GTX 670 FTW SIG 2/Cooler Master HAF-X
http://www.speedtest.net/my-result/3591491194
https://linustechtips.com/topic/167929-nvidia-control-panel/#findComment-2234142
Yeah, I wouldn't set maximum performance under global settings. For game by game tuning I would.
https://linustechtips.com/topic/167929-nvidia-control-panel/#findComment-2234149
