Power adapters questions/problems
Solved by Enderman,
OK, but here is just some information about his PSU:
His PSU is a Maxcube nira 400W
I found these specs:
+3.3V 20A
+5V 14A
+12V1 14A
+12V2 13A
-12V 0.8A
+5Vsb 2.5A
Somebody told me on tom's hardware forum that "According to Asus you need about 225W = 19A at 12V" and this PSU got only 14 amps on the 12V (don't know why there are 2 12Vs in the specs though)
And I don't even know where did the got those numbers.
One of the 12v is for the PCI-E power connector, and the other 12V is for molex+sata power
So if you put then together with the adapters it is 14+13=27A which should be enough
