Choosing a UPS
Go to solution Solved by Peter Vaughan Truslow,
That's very cheap indeed, but as I don't live in the US I'll take this one . Any rough idea of how long I can expect to keep my monitor and my computer on?
looking at their graphs, I'd wager you'll get something between 40 minutes and an hour on that at idle. maybe 15 minutes on a gaming load
Hi,
I'm trying to determine the size of the UPS I should buy. Ideally, I would like something to keep my system up for an hour in case of a power cut but I don't have the budget for that. Basically I want the best price to backup time ratio.
My monitor is a Samsung SyncMaster F2380. I tried to determine its power consumption. I can find here that it uses less than 40W, but when I try to calculate its consumption myself based on the information given behind the monitor, I get much more values. Here is what I see :
AC 100-240 1.0A
When I use the method described here I find 240W so I don't know who to believe.
Besides the monitor I have a PC with a core i3 4330 and a GTX 750 Ti. Based on these charts I can see that it will require less than 100W.
So I'd like to know what is the actual wattage/consumption of my monitor, then what UPS would be appropriate. What can I expect from a 390 Watts / 650 VA UPS?
Thanks
https://linustechtips.com/topic/167801-choosing-a-ups/
my recommendation is the same as his. buy or borrow a Kill-a-watt etc and plug everything you want to back up into it. turn your monitor brightness up all the way and stress your computer as much as possible. add another 10-25% to whatever you draw and that's what you want your UPS rated for.
I have a 27 inch LED monitor, a quad core intel processor and a 660 TI and I could get away with a 400W UPS, but to be safe I have a 650W/1000VA UPS which would still be within that power envelope if I added a second graphics card.
https://linustechtips.com/topic/167801-choosing-a-ups/#findComment-2232483
How long does your computer stay on with your 650W/1000VA UPS?
https://linustechtips.com/topic/167801-choosing-a-ups/#findComment-2232518
according to this source: http://www.pcstats.com/articleview.cfm?articleID=2492 your monitor should draw in the ballpark of 45 watts, about average for a CCFL 23 inch LCD
your computer will as you said probably draw in the ballpark of 100 watts if you have an efficient power supply. if your UPS can deliver 200 watts, you should be pretty safe
something as cheap as this should do just fine: http://www.amazon.com/CyberPower-CP350SLG-Standby-350VA-Compact/dp/B004OR0V2C/ref=sr_1_10?ie=UTF8&qid=1403039330&sr=8-10&keywords=UPS
https://linustechtips.com/topic/167801-choosing-a-ups/#findComment-2232530
https://linustechtips.com/topic/167801-choosing-a-ups/#findComment-2232622
https://linustechtips.com/topic/167801-choosing-a-ups/#findComment-2232840
Get APC. :P
System 1: Thermaltake Element Q - Thermaltake 220W SFX - Asus AT5IONT-I mini-ITX - Intel® Atom™ D525 onboard 1.8GHz Dual-Core HT - Integrated NVIDIA® ION™ - 2x 2GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
System 2: Thermaltake Element Q - Thermaltake 220W SFX - Asus E2KM1I-DELUXE mini-ITX - AMD E2-2000 onboard 1.75GHz Dual-Core - Integrated AMD® Radeon HD 7340 - 2x 4GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
Building: Bitfenix Prodigy Black - Corsair AX860i - Asus Maximus VII Impact - Corsair Hydro Series H100i - Intel® Core™ i7 4790K - Asus Matrix Platinum GTX 980 4GB - Corsair 16GB Dominator Platinum 2x 8GB DDR3 2400MHz CL10 - Samsung 1TB EVO 840 Series
https://linustechtips.com/topic/167801-choosing-a-ups/#findComment-2233755
