Hi everyone, new member here.
I been following Linus on youtube for about a year with the aim of eventually building a gaming PC and this seemed like the right place to come for some advice.
So here's the requirements, it has to run triples mostly for sim racing titles like Project Cars and Assetto Corsa. I'll also play Fifa and whatever else takes my fancy.
It will need to be easy to keep cool, no aircon and I've a small gaming room with 3 32" lcds and 6 amps running Buttkickers so it can get pretty hot on a summers day. I will be looking into aircon solutions after the PC build.
I'll need multiple sound cards, the on board plus two more, one for sound and two for simvibe software for sim-racing.
Really my trouble is with what I really need versus what would be just overkill. I am willing to spend money now rather than upgrading in one or two years time. That said I'd like to keep costs to £2000-£3000 max the lower in bracket the sooner I can get started. I've started the fund already and should have the rest in 8 weeks.
Looking forward to your thoughts and thanks in advance for taking the time to help!  :)
This is what I've been looking at
https://uk.pcpartpicker.com/user/Carson79/saved/#savedbuild_1195024
Am I on the right track?
https://linustechtips.com/topic/167646-first-gaming-pc-build/
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor  (£227.99 @ Aria PC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  (£81.60 @ Amazon UK)
Motherboard: Asus Maximus VI Extreme ATX LGA1150 Motherboard  (£292.92 @ Ebuyer)
Storage: Mushkin Chronos 480GB 2.5" Solid State Drive  (£155.99 @ Aria PC)
Video Card: MSI GeForce GTX 780 Ti 3GB TWIN FROZR Video Card  (£499.99 @ Amazon UK)
Case: Corsair 900D ATX Full Tower Case  (£263.99 @ Aria PC)
Optical Drive: Pioneer BDR-209DBK Blu-Ray/DVD/CD Writer  (£51.92 @ Amazon UK)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  (£79.99 @ Amazon UK)
Sound Card: Asus Xonar Essence STX 24-bit 192 KHz Sound Card  (£131.84 @ CCL Computers)
Total: £2288.71
Generated by PCPartPicker 2014-06-17 15:17 BST+0100
For those who dont want to click.
Lemme help you out a bit. Give me a second to write some things up. @Carson79
BTW, Welcome to the forum.
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230323
Personally i would go with the 780 ti build, you can also save some money on this too. i see that you have selected a 1200w PSU you most likely won't need this unless you are going to put another 780 ti in there which i suppose you may do as you have a maximum of £3000 budget. but if you were to go with just one 780 ti then go for a corsair 850w RM Gold powersupply it will be perfect for it. I also see you have gone for a top of the line case, the 900D is great for air cooling so this will deafinity be ok however i also think you could save some money here but you have that your room that you play in can get quite hot. Lastly the 780 ti whilst extremly good for one monitor it may not be quite as good for three, i would strongly reccomend going with a titan black as it has 6gb of vram which will be perfect for running three monitors whilst gaming! http://www.dabs.com/products/asus-geforce-gtx-titan-black-6gb-pci-express-3-0-hdmi-992F.html?utm_source=google&utm_medium=ppc%20product%20search&utm_content=Q200&utm_campaign=Components%20and%20Storage%20-%20Graphics,%20TV%20Tuners%20and%20I/O%20-%20Graphics (if you go with titan black stay with at least a 1000w psu)
 My PC: CPU: i7 4770K @ 4.2 Ghz MoBo: ASUS Z97-ATX SLI RAM: 8GB (2x4) 2400Mhz GPU: Palit Jetstream 780 TI Memory:1TB Seagate + 120Gb Kingston SSD  PSU: Corsair RM 850W Gold Monitor iiyama 27" 144hz Monitor CPU Cooler Corsair H100i
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230330
900D is way too big. It will feel so empty without custom loop. Find something a little bit smaller like 750D or 760T if you only want full tower.
The motherboard is overkill imo. You can find something with same features with half the cost.
With that budget youy should go with 2 video cards. 2x780s or 2x r9 290s.
Psu is waaay overkill. Search something like 850 watts of power for 2 video cards,650 watts for single card.
Also,this belongs to new builds and planning section ;)
Edited by SpyRosL
 i5 3570k @4.all over the place || CM Hyper TX3 Evo || ASRock Z77 professional-m || 8GB G.SKILL Ripjaws Z 2400mhz CL10 || MSI GTX770 2GB OC'd 1280/3825mhz || ADATA SP900 128GB || Fractal Design Arc Mini R2 || Logitech G502 || Audio Technica ATH-M50
A spy is always better than a ninja!See burn notice. EVERYTHING is just a number!
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230333
900D is pretty overkill with only a 260mm rad, check out the 750D its cheaper
Intel i7 4702MQ| Nvidia GTX 850M| Kingston 16GB DDR3 1600Mhz| Acer VA70_HW (mobo)| 1TB WD Blue| MATSHITA DVD-RAM UJ8E0|1600x900 display|Win 8.1
Intel i5 4690K @Stock| Sapphire 390 Nitro| Hyper X Fury 2x4GB| MSI SLI Krait z97| Noctua Nh-U12S | 850 EVO 256GB| 2TB WD Black | CM V 850w| Enthoo Luxe
If you want to tag me or any person with periods do: @[Member='Name]
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230340
This is miles better.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£267.73 @ Overclockers.co.uk)
CPU Cooler: NZXT Kraken X60 98.3 CFM Liquid CPU Cooler  (£99.98 @ Aria PC)
Motherboard: Asus MAXIMUS VII RANGER ATX LGA1150 Motherboard  (£129.56 @ Scan.co.uk)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 Memory  (£130.99 @ Scan.co.uk)
Storage: Samsung 840 EVO 1TB 2.5" Solid State Drive  (£335.99 @ Aria PC)
Video Card: MSI GeForce GTX 780 3GB TWIN FROZR Video Card (2-Way SLI)  (£339.95 @ Aria PC)
Case: Corsair 760T Black ATX Full Tower Case  (£129.99 @ Ebuyer)
Total: £1996.14
Generated by PCPartPicker 2014-06-17 15:26 BST+0100
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230358
Do you really really like the 900D? or are you okay with a different case? The 900D is pretty chunky and unless you want water-cooling I wouldn't suggest it :/ Why not get the 750D instead? it's basically the same thing without the ridiculous height.
here's what I've come up with. £200 over 2000 but this should last you a few years :) (wayy overkill for single monitor but for your 3 32'' lcd's, this is required.)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard  (£164.36 @ Scan.co.uk)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory  (£118.99 @ Scan.co.uk)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive  (£179.99 @ Aria PC)
Video Card: MSI GeForce GTX 780 Ti 3GB TWIN FROZR Video Card (2-Way SLI)  (£499.99 @ Amazon UK)
Case: Corsair 750D ATX Full Tower Case  (£121.76 @ CCL Computers)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer  (£11.88 @ Amazon UK)
Case Fan: Corsair Air Series AF120 Red 52.2 CFM 120mm  Fan  (£7.98 @ Ebuyer)
Total: £2411.07
Generated by PCPartPicker 2014-06-17 15:36 BST+0100
EDIT: You might want to get some after market case fans and 2 SP 120's for that H100i. Also, switch out the WD Black for Green ones which run cooler and quieter. Just saw your cooling requirements.
EDIT2: Edited build with changes mentioned.
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230370
Total: £1996.14
Thanks mate, would the psu be okay when I add two sound cards? This is really the help I'm looking for, I really would prefer it to be a wise build rather than a contest of the most expensive parts lol
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230383
Total: £1996.14
Yep that PSU would have no problems at all. But I question your need for dual sound cards. I have never heard of a system that needs that. Can you expand on your setup a little bit to help us understand what exactly you are needing that for?
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230392
Yeah I really liked the 900D I had been looking at the Cooler Master cosmos but liked the simplistic design of the 900D
if you deafinitly going to go for a 900D then don't go for a 780 ti, you really should go for a titan black. ( it will literally double the 780 ti's performance and also a=has 6gb of vram which is becoming more and more important)
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230406
Sorry the duel sounds cards are needed for software called simvibe its drives buttkickers to simulate engine and road vibrations and other effects that make the cockpit shake and vibrate more realistically than just sound driven buttkickers. It is quite amazing effects
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230413
After the PC build I'll be getting better monitors, so is the Titan black the way to go then?
if your only going to be using 1 monitor then stick with 780 Ti, if your getting anymore monitors i.e 3 then i suggest the titan black by far. :)
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230436
Also one kind of monitors where you thinking of and also what resolution?
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230444
Lol What?!?! This is complete bogus and I would ask you to stop spreading misinformation around.
Source: http://www.pcgamer.com/2014/05/08/gtx-titan-black-the-ultimate-gaming-gpu/
The Titan black often performs worse in gaming than the 780ti, but will do better in compute calculation situations.
No, disregard what @xD6N said. The titan Black is incredibly bad value for a gaming PC.
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230453
oops, sorry about that my mistake.
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230462
That's okay, I thought that 2 780ti's were better from reading it somewhere. I think they run cooler than two R290x's as well?
The case isn't a big deal just personal preference, I may get the system water cooled down the line, but first things first lol baby steps as I will be doing all this for the first time myself
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230482
The case isn't a big deal just personal preference, I may get the system water cooled down the line, but first things first lol baby steps as I will be doing all this for the first time myselfyes
this will be great and will fit all of your tasks http://www.ebuyer.com/640880-msi-r9-295x2-8gb-gddr5-dvi-4-x-mini-displayport-pci-e-graphics-r9-295x2-8gd5?utm_source=google&utm_medium=products&gclid=CJOVtb-Wgb8CFSjpwgodolYAsA
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230500
I'm undecided on 32"LED tv between £250- £350 or 29" monitor in the £300-£350 bracket.
The most important thing is bezal size.
so you will only be going with one monitor? becuase if you are then just stick with 780 ti ( also look for 144hz monitors ) theese monitors display more fps than a regualr 60hz monitor.
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230523
Here is kinda the pecking order for Nvidia GPU setups: 780 < 780ti < 780 SLI < 780ti SLI The higher up the chain you get the hotter the system gets but the better it performs.
You basically got two options.
What Real_Phillbert recommended which saves you a bit of cash or what IcedEskimo suggested if you want to go all out.
In any case, both are excellent builds.
Yep @IcedEskimo 's build is very solid. It will perform slightly better than my build, but run a bit hotter and be a bit louder. Its all about the preference of the user, and how much he wants to spend. Both would be very good options.
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230532
Yeah I like both, and at £2400 with two 780ti's it's still good value imo
https://linustechtips.com/topic/167646-first-gaming-pc-build/#findComment-2230539
