Custom loop is always the best, if you can afford over $1k that is.
https://linustechtips.com/topic/167416-best-liquid-cooling/#findComment-2227485
Are you in Canada?
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/167416-best-liquid-cooling/#findComment-2227522
I'm also in the same boat. I'm pretty new to water cooling and have a budget of 100-200$. Kinda want an all in one as the appeal of a custom loop isn't there for me.
I'm considering the corsair hydro series H80i at the moment.
Asrock x79 extreme6, intel 3820, gtx 980. 16gb patriot 2133mhz, h100i
https://linustechtips.com/topic/167416-best-liquid-cooling/#findComment-2229094
Okay... Haha I'm looking between 100- 200 and want an all in one... To start anyways, and would prefer dual fan :D
I recommend either the Cooler Master Glacer or the Swiftech H220.
They are basically the same thing and both expandable if you need it later on.
https://linustechtips.com/topic/167416-best-liquid-cooling/#findComment-2229220
