Wich cpu cooler
Go to solution Solved by PassionFruit,
Maybe the Hyper 212 Evo?
Definitely. AMD CPU's run hotter than Intel's do and their stock cooler is the worst. If you want easy to install I'd go with the Noctua NH-D14 or NH-D15. They both use the best mounting hardware in on the market SecuFirm something I think it's called.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/167099-wich-cpu-cooler/#findComment-2224038
Is it easy to install? it's going to be my first build.
The CM Hyper 212 Evo is just as easy to install as a factory heat sink. Same process. I recommend the 212 Evo as well after my extremely positive performance of mine.
Never say it's not broken. Everything is broken. Why? Because everything needs MOAR POWA!
https://linustechtips.com/topic/167099-wich-cpu-cooler/#findComment-2224263
yes, really really easy you shouldnt have any problems
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/167099-wich-cpu-cooler/#findComment-2224322
why would you tell someone to spend more on their CPU cooler than their CPU.....
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/167099-wich-cpu-cooler/#findComment-2224330
