Hello all....I have a small form factor pc that I am running and can only use a low profile graphics card. My question is has anyone used a pci express 16x to pci express 16x cable extender like the one listed in the link below. If so please tell me is it even worth trying to run it as my primary gpu slot.
http://www.amazon.com/gp/aw/d/B00HZ0M9F2?vs=1#immersive-view_1402913348061
https://linustechtips.com/topic/167057-pci-express-extender-cable/
Hello all....I have a small form factor pc that I am running and can only use a low profile graphics card. My question is has anyone used a pci express 16x to pci express 16x cable extender like the one listed in the link below. If so please tell me is it even worth trying to run it as my primary gpu slot.http://www.amazon.com/gp/aw/d/B00HZ0M9F2?vs=1#immersive-view_1402913348061
Are you gaming with the GPU? Or mining?
If gaming, this extender won't work as it is coming from a pci-e 1x slot.
You need a 16x - 16x extender.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
you can exte,d 4x to 8x and 8x to 16x, it will still have the same electric spec, but will be able to hose larger cards
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
sure you can
sure you can
1x - 16x?
No, you can't, why do you think we have 16x slots. Why not just run a GPU with a 1x slot.
1x - 16x?
i didn't say 1x/16x, i said extending the 16x slot to use a graphics card externally is possible
The video post gave me the information needed, I need a full 16x to run the graphics card.
there you go
Your totally right....what I thinking, have you ever tried doing this type of setup?
did it to a friend once where he had the exact same situation as you, a small form factor but he didn't dig Blower fan cooled GPUs, so we got his an EVGA GTX 760 ACX and modded the case to screw it on to the outside
Make sure the extender cable is labeled as "POWERED" or else it will fry the PCI-E lane
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
On which side?
mobo side. the mobo will try to feed power to the PCIE lane and there wont be any power and burn out the lane.
