Hi!  :D
I'm looking to replace my Mouse and Keyboard, as after 2years , start to wear out.
I'm looking though alot of reviews etc, but there is so much out there! I'm wondering if any of you could recommend some stuff?
I'd love to have a Mechanical Keyboard, and a mouse with Weight to it.(Adjustable)
Budget about 70$ per keyboard/Mouse, so about 140$ Total.
Currently use a TtSports Keyboard, and a Rocat (or something) R.A.T 3 < Really like this mouse and may get a R.A.T-5
Thank you all for reading and responding! :)
https://linustechtips.com/topic/165734-help-looking-to-replace-my-stuff/
The choice is very personal and it depends on your hand size and grip style.
If you can, you should make use of Amazon's great return policy and just order 4 mice that you find interesting, test them for a week and send 3 of them back. It's not nice, but it helped me find my mouse.
Because normally, when you walk into a tech store they have your typical Logitech and maybe a razer and a roccat mouse and that's it.
I bought a CM Storm Havoc. It's very inexpensive for the stuff that it packs (Omron switches, good laser sensor, multi color LED, software cusomization) and most importantly, it fits my hand (large) and grip style (tip grip).
who cares...
G502 from Logitech is a decent mouse.
Think i'll go with the R.A.T-5 As it is on sale atm :)
Thanks for the feedback!! :)
I'll probably go with the R.A.T5 Mouse, just looking for a keyboard now :)
keyboard depends on your taste of buttons and stuff. I currently have a CM storm with cherry mx blues and i love it. it has red LED backlighting, has these function keys and stuff, nothing too fancy, so yeah.
this pic here, it's not mine, but it is almost the same. I have QWERTZ keyboard layout, but that's the only difference
28404d1342025891-cm-storm-quick-fire-pro
Thanks for the reply, it looks good, i'm not looking for anything fancy, so far i only used Rubber Dome Switches, and would love to try a Mechanical keyboard.                                                  I'll put it on the list :)
