So I'm building my first PC. I am NOT computer illiterate or anything but I've never built one from scratch. I've replaced laptop screens, hard drives, normal computer innards ya know, the usual. But, like I said its my first so it's gonna be my baby. I'm a twitch streamer so I need a really great setup. So far I'm looking at spending 1.1 G so far. I'm wiling on going 1.5 G but I will have to save A LOT. This build will be for a gaming build. I will provide my current pieces of hardware (NOT OS YET! Most likely going with Windows 8 however) with Amazon link.
Corsair CX Series 500 Watt ATX/EPS Modular 80 PLUS Bronze ATX12V/EPS12V 456 Power Supply CX500M
LG Electronics 14x SATA Blu-ray Internal Rewriter without Software, Black (WH14NS40)
Arctic Silver 5 Thermal Compound 3.5 Grams
AMD FD8350FRHKBOX FX-8350 FX-Series 8-Core Black Edition
Corsair Vengeance 32GB (4x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMZ32GX3M4X1600C10)
MSI ATX DDR3 2600 LGA 1150 Motherboards Z97-G45 GAMING
ASUS GTX760-DC2OC-2GD5 GeForce GTX760 2GB GDDR5 256-bit, DVI-I/DVI-D/ HDMI/DP PCI-Express 3.0 SLI ready Graphic Card OC-selected 1072 MHz core
Cooler Master Seidon 120V - PC CPU Liquid Water Cooling System, All-In-One Kit with Compact 120mm Radiator and Fan
Corsair Air Series SP120 Quiet Edition Twin Pack Fan (CO-9050006-WW)
Feel free to provide constructive criticism! Anything helps!
https://linustechtips.com/topic/165672-my-first-pc/
oh god this is a mess...
budget and location?
you know a amd cpu won't work with a intel motherboard right?
please post under the right sub form next time this belongs in new builds and planing
use the quote button if you want my help
also you DO NOT need 32gb for gaming
Specs
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205199
this isn't just for gaming. Like I said, I'm also a streamer.
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205206
streaming doesn't require 32gb ram i stream on 8gb just fine...
but please answer the rest of my questions if you want a better system that will actually work
Specs
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205209
Streaming does not need 32GB RAM.
No like you put an AMD CPU with an Intel socket. It won't fit.
Bahahah I just noticed that!
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205213
also thanks, i did not know that an AMD processor would not work with an intel motherboard.
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205216
These days, Single core performance>Number of cores. Use http://pcpartpicker.com
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205224
what other questions do i need to answer?
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205226
location but im just going to take a guess and say that your from the us and if you are go with something like this and save allot of money
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($143.99 @ NCIX US)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  ($114.00 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($84.98 @ OutletPC)
Video Card: EVGA GeForce GTX 770 2GB Superclocked ACX Video Card  ($309.99 @ NCIX US)
Total: $1030.38
Generated by PCPartPicker 2014-06-13 02:49 EDT-0400
Specs
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205232
Lets not be too rude, even if its mostly true :P
sorry bad day = grumpy mode
Specs
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205235
Intel option. You can change Case, storage options to your liking, but that will stream for you.
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor  ($269.99 @ Micro Center)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.99 @ Best Buy)
Motherboard: MSI Z77A-G45 ATX LGA1155 Motherboard  ($123.98 @ SuperBiiz)
Storage: Samsung 840 Series 120GB 2.5" Solid State Drive  ($133.45 @ SuperBiiz)
Video Card: Asus GeForce GTX 760 2GB DirectCU II Video Card  ($216.60 @ Newegg)
Optical Drive: LG WH14NS40 Blu-Ray/DVD/CD Writer  ($67.99 @ SuperBiiz)
Total: $1364.95
Generated by PCPartPicker 2014-06-13 02:51 EDT-0400
My Rig: . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205238
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1866 Memory  ($153.99 @ Newegg)
Storage: Western Digital Caviar Black 2TB 3.5" 7200RPM Internal Hard Drive  ($148.98 @ OutletPC)
Case: Fractal Design Define R4 w/Window (Titanium Grey) ATX Mid Tower Case  ($99.99 @ Newegg)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Amazon)
Total: $1364.95
no...please no...
Diamond 5 in League :)
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205245
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205248
Total: $1030.38
Yeah this is probably the best alternative here, i would go for this.
Case: Corsair Carbdie 330R Motherboard: Gigabyte GA-970A-DS3P Asus Z97-A CPU: AMD FX-6300 i5 4690K 3.5 GHZ + 212 EVO GPU: ASUS GTX 760 DirectCUII Ram: Corsair Vengeance LP 8gb (2x4gb) HDD: Seagate Barracuda 1TB PSU: Corsair CX500M
Monitor: AOC Q2963pm 29'' 21:9 IPS Mouse: Mionix Naos 8200 Mousepad: Mionix Sargas 320 Headset: HyperX Cloud Keyboard: Corsair Gaming K70 RGBIKEA Headset/Headphone Holder
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205291
That's not bad except for a few things. There's no reason to go for a black drive if you already have an ssd. Just grab a 1TB blue or a cheaper 1TB. Also, you can get a better power supply than that for $100. Lastly I'm not that fond of that case but that part is personal opinion.
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205298
i will look into all of these i really appreciate all the criticism!
Hey there are some good and bad things about all the builds posted. Personally I don't care much for any of the psus listed because they are a bit overpriced for what they are. You can get an XFX 750 watt for $100 and those are one of the best (Seasonic OEM). There are definitely good ones out there for less than $100 since 750 watt is likely overkill for whatever gpu you might end up getting. If you let me know a budget, I can make a build for you but it'll have to be tomorrow because I'm going to sleep now. Also, if you are near a microcenter, you can save a alot on a cpu and motherboard combo from there.
https://linustechtips.com/topic/165672-my-first-pc/#findComment-2205312
