I recently installed and started using NZXT's Cam software I have really liked it but I'm finding my cpu temps are ridiculously high.
I'm using an Antec H20 630with artic silver 5 with push pull on the rad. My temps are hitting as high as the mid 90s c! What do I do?
    CPU - AMD 6800k; Mobo - ASRock FM2A88M-HD+; RAM G. SKill 8GB(2x4gb); GPU - NVIDIA GeForce GTX 580; Case - NZXT H230; Storage - Toshiba 1tb HDD, OCZ Agility 3 120 gb; Silverstone 600w 80+ bronze; Display - Dell 24 in., Generic 20 in.; Cooling - Antec Kuhler H20 620; Keyboard - Genereic Dell; Mouse - Logitech m510; Sound - Syba USB 2.0 DAC
https://linustechtips.com/topic/165221-cpu-temps/
What CPU are you using? Are you running Prime95 or some other stress test?
https://linustechtips.com/topic/165221-cpu-temps/#findComment-2198828
I tried a few different software and they all gave me different readings, but the cam software was 30c over the next reading.
https://linustechtips.com/topic/165221-cpu-temps/#findComment-2206966
So I'm assuming then CAM is screwed up cause it's new?
https://linustechtips.com/topic/165221-cpu-temps/#findComment-2207052
