Hi everyone, I have 2 questions.
1. In the CPUID, I have constant 128 degree celcius on my TMPIN02. is that normal? if not, how to fix it?
2. I am a total newbie in overclocking. I have 4670k on 97z. Do you guys know where is the better way to start off learning?
Thanks everyone in advance! pro overclocker~ :D
https://linustechtips.com/topic/164484-help-needed-overclocking-tips/
@zion319
You could watch Linus' videos about Haswell overclocking.
Also what cooler do you have?
I have the CoolerMaster 120XL. Right now, I am getting pretty good temp. 28 idle and 48 or less on gaming mode. So I am thinking to overclock a little. But I havent run any stress test yet.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
Some updates could fix that, most likely a bios update. but do not worry about it right now, you're barely in the water, how dare i dunk you and suggest you to update the bios.
Oh, and it's fine btw. Just an error.
Read all of the guides. there's a tech tip
