so im thinking of upgrading to and SSD in my Lenovo y580 laptop and i have a few questions.
1.which (128GB) ssd should i buy?
2. should i use it as cache for my 1tb HDD which has my os and everything on it
3. should i replace my blu-ray drive and use it as an external?
if yes please also recommend any external case for the blu-ray drive
https://linustechtips.com/topic/16433-ssd-upgrade-time-need-help-for-setup/
get a samsung 840 pro. and use it as a whole drive and get a 60gb later and use it as cache
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
..or a Kingston 3K, it's cheap and fast!
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
The 840 pro is a great option, as well as the OCZ vertex 4. If you are thinking of taking the blu ray drive out, and putting the ssd where it was, that could be a good option. However, you should probably set it up as the ssd for boot drive/applications and the 1tb for data/pictures/movies.
