need 14+ non-noctua fans for "silent" 900D. recommendations?
Solved by Syntaxvgm,
I've used these. Pretty quiet. http://www.newegg.com/Product/Product.aspx?Item=N82E16835553005
With that many fans though I'd get a controller to make sure it's quiet.
Good for general fans. Lemme look for better rad/hsp ones.
OOOh purple
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181053
Actually for hsp http://www.newegg.com/Product/Product.aspx?Item=N82E16835181040
why not. They got the different color rings you can take off.
you'd want a controller for those though.
