So I'm buying a new subwoofer for my audio setup but being the newb that i am i need some help basically what i need to know is if the powered 3.5mm output from my PC will damage the passive inputs on my new sub
if you bought a passive subwoofer, you will need to buy an amp. the 3.5mm output will not power a subwoofer.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
As an audiophile I would recommend buying a nice system with a built in amp. If you already bought the sub, bob345 is correct.
I'm not an audiophile, I'm just really picky about my music... and my headphones... and my speakers... and my microphone. Other than that, I'm totally not an audiophile.
Oh yea, think about where the sub should be placed and where your head will be while listening. When I went around the room doing stuff and using the speakers, moving from center of the room to the corner of the room, the bass changes drastically.
In Placebo We Trust - Resident Obnoxious Objective Fangirl (R.O.O.F) - Your Eyes Cannot Hear
Haswell Overclocking Guide | Skylake Overclocking GuideCan my amp power my headphones?
i think my original post may not have been perfectly clear the subwoofer is a powered unit and i know that the 3.5mm outputs on PC's are powered and i've heard that using a powered output to connect to the input of a powered unit is bad so i just wanted to get your opinions on whether or not it will actually cause any substantial damage
PC outputs will not damage the input on any consumer product.
