?Help! :) Is this system going to work ok?
Solved by Goodmane,
There will be enough 8 pin connector coming with your PSU or there will be an option for it.
And I would suggest looking into other websites if you are going to order online. I found same PSU for 10 pounds cheaper then that website
You might not be able to copy your working operating system to SDD, it will require you to copy both partitions of windows boot partition and OS installation partition. It would be much more easier and faster just to do a clean install.
This PSU looks better if I have to be honest. And price is same. And it has modular 8 pin PCI outputs.
