Hey there,
Been having a weird issue where my pc will crash and my screen will freeze but it won't restart itself or shut down. Looking in the event viewer the attatched 'informational' event occurs in every single record of this freeze I have (sample size of about 7). From what I can see when looking it up the event itself isn't anything to worry about but I'm just slightly confused why if it isn't anything to worry about, it is the last thing that is procesed before the crash ensues.
If anyone has any idea of why there is a pattern here or if anything can fix it that would be much appreciated :)
https://linustechtips.com/topic/1636794-pc-crashing-problems-with-weird-pattern/
Posted (edited)
Is your bios (always) up to date ? you know that cpu is flawed and could be faulty ?
You could run that Intel Processor Diagnostic Tool (no idea if it's any good for finding out)
It crashes randomly ?
Did you check your Ram with a Memtest86 ?
Edited by leclod
If you don't quote us, we won't know you answered
43 minutes ago, Flame22 said:
i9-14900k
please have Bios updated
2tb samsung ssd
see if it needs firmware update
44 minutes ago, Flame22 said:
32gb corsair vengeance 4600Mhz
2 sticks? Only 4600Mhz?
If you have 2 sticks, physically you can test RAM by trying running just one, and then the other if any have problems when only specific stick is used
On random, or when playing games, or?
current PC:
PC configs I used before:
