Hey guys my cpu temps seems off when im at like 25precent usage - 30  im at like at 65c and im using an 360mm aio which was said beeing an overkill for this cpu whats wrong with the temps ? my rare exacust fan is 120m and im pretty sure i can fit 140mm one maybe that will make the diffrence or swaping the front fans to better onces ? all those fans are the stock case fans , my pump is runin at max 2824
all the parts expect the gpu are like 6 months old
  • Case: NZXT H7 Flow RGB (2023)
  • CPU: AMD Ryzen 7 7800X3D
  • CPU Cooler: Arctic Liquid Freezer II 360 mm AIO (mounted at the top)
  • Motherboard: ASUS ROG STRIX B650-A GAMING WiFi
  • GPU: Gigabyte RTX 3070 OC
  • RAM: G.Skill Flare X5 — 32 GB (2×16 GB) DDR5 6000 MHz CL30
  • Storage:
    • Samsung 990 EVO Plus 2 TB NVMe M.2 SSD (for games)
    • SATA SSD (for Windows)
  • Power Supply: Super Flower Leadex V Pro 850 W PCIe 5.1 Platinum
https://linustechtips.com/topic/1636326-cpu-7800x3d-temp-help/
  • Storage:
That sounds about right for a 7800X3D. AM5 run warm and 65c at 25-30% load is absolutely expected.
I see nothing wrong here at all.
My 7700x did the same and my 9800X3D sits at 60c at 12% load at the moment.
https://linustechtips.com/topic/1636326-cpu-7800x3d-temp-help/#findComment-16891986
maybe anyway to make it better i mean saw a guy runing it with an air cooler at 80% 66C surely my aio can get better temps
https://linustechtips.com/topic/1636326-cpu-7800x3d-temp-help/#findComment-16891987
Show me that video, he might have been running with the fans on the air cooler at 100% speed with a CO ( Curve Optimizer undervolt )
There's no maybe, its just how it is. AM5 spikes in temps all the time.
If you gaming temperatures are good I see no reason to worry, you can try to increase the pump speed on the AIO.
But 60-80c on a 7800X3D is perfectly normal during gaming, even with a 360mm AIO.
https://linustechtips.com/topic/1636326-cpu-7800x3d-temp-help/#findComment-16891989
I heared Antarctica was sub-optimal cooler for high-end AM5 processors.
They simply run that warm and it's absolutely fine, even if it was constant 80C temps it's still about 15C away from max temps the CPU allows.
And even then some AM5 CPUs on 100% all-core load can reach 95C and stay there without any problems, they were designed for speed so they hover on higher thermals when put to work.
current PC:
PC configs I used before:
https://linustechtips.com/topic/1636326-cpu-7800x3d-temp-help/#findComment-16891992
7800x3d runs at 55-65c at almost any load. It's not linear
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1636326-cpu-7800x3d-temp-help/#findComment-16891999
Without seeing package power along side temperature, not a whole lot can be suggested. Usage doesn't matter much, but power does.
Either way if you're concerned you want to be running a max load test and taking note of peak package power and temp.
No sense in worrying about what temp is doing beneath max load.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1636326-cpu-7800x3d-temp-help/#findComment-16892002
wondering if its worth runing curve optimazr -20 on all cores
https://linustechtips.com/topic/1636326-cpu-7800x3d-temp-help/#findComment-16892216
It is.   But don't expect miracles.  It helps a little tho, yes.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1636326-cpu-7800x3d-temp-help/#findComment-16892291
