Posted (edited)
A family member has been having wifi download speed issues as of late. They are using Win 10 and have previously been using a cheap TPLink USB dongle. It had been working fine up until recently (sadly I don't have a speed for before it slowed down).
-The plan is 450 download 10 upload in Mbps (from now on I will be talking in terms of download speed)
-They were only getting 2-3 Mbps download
-Works just fine when Ethernet is plugged in
I decided to tell him the buy this adapter
https://www.amazon.com/TP-Link-Bluetooth-Ultra-Low-Archer-TX3000E/dp/B07ZV2CJL2/
After installing the adapter in the top x1 slot  of his B450M Asrock Steel Legend motherboard, this happened (pc specs: https://pcpartpicker.com/list/2H8jZc)
-Download speed increased to ~10 Mbps
I get similar results when I used my Gigabyte antenna that was included with my motherboard, which gets 350 on my personal computer.
What could be causing this issue?
I am lost as I don't know what else to do.
Edit: As of this post, I am currently reading through the mobo quick start quide.
Edited by Cringe_Master245
https://linustechtips.com/topic/1635330-need-help-with-wifi-issues/
 Interference. Keep in mind that walls and other obsticals will cause issues. Placement of the router can be important. For example directly above and below the router will be dead zones due to the WiFi signal coming off the antennas in a doughnut shape.
Other WiFi networks on the same or adjacent channels can cause issues. For example 2.4 Ghz at least in the US only has channels 1 - 11 usable. Channels 1,6,11 are the only channels that dont overlap. If you have lots a neighbors close they could be clogging the spectrum. Even now days 5 Ghz has started getting full. THe issue with 5 Ghz is part of the spectrum is shared with radar (DFS Channels), in order to use these channels additional certifications are needed and many routers thus dont support DFS channels.
Other devices using the same spectrum. 2.4 Ghz is used by Bluetooth, Microwaves and other wireless devices (Mice, keyboards cordless phones). Ive seen 5 Ghz used to an extent on other devices as well.
You might have to reconfigure the network. IF you have an Android device, download WiFi analyzer. This will allow you to check the spectrum. Check to see what WiFi channels could be free. Also will allow you to check signal strength thru the house.
Other than that you can try changing the WiFi channels, to see if that helps. Also keep in mind that higher bands like 5 and 6 Ghz has less range and penetration power. So that could be an issue. 2.4 Ghz is much better for penetration and distance, but can be a bit slower. This is important because WiFi prioritizes stability over speed. Meaning the further you get out from the router, the slower the link speed will be.
You might also try moving the router, for most this is hard to do. But putting the router up higher can help spread the signal. Try moving the antenna of the WiFi card around.
If all else fails, replacing the router with a Mesh system will likely be the solution. But that potentially comes with its own challenges depending on the ISP/Internet type.
How far from the Router is the PC?  What parts of the house are in the way?
What speeds do you get plugged in by wire?  What wifi speeds do you get on your phone at the PC's location?  Next to the router?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Posted (edited)
-The router is currently in the basement  behind about two walls, although my personal computer is only behind one American wall (drywall and some noise insulation) (will have a measurement in ft once I'm home), but still gets ~350Mbps (down)
 -with a wire, I get the full 450 Mbps (upload is unaffected [other than loss from wifi vs wired] on both computers)
-will test with my phone when I am home
-Both computers are in the basement with the router being elevated compared to the two computers
Luckily, I do not have to worry about any neighboring wifi networks.
Will download and report back on what I find.
I should also mention that the 2-3 Mbps number was taken at the spot the family member's pc will be(with the cheap dongle)
All other numbers were taken with their pc next to mine (closer and less obstructed [maybe?] from the router).
Wait.  The 2-3Mbps number is with your phone or laptop?  The family members PC isn't even there yet?
OnePlus Ecosystem:
3D Printing:
The 2-3 number is from when the family members computer when they were using the Wifi dongle I'm their room(we live in the same house).
All the other numbers were after I moved it to my room for testing.
Both computers are desktops
Might get better Wifi with a positional antenna...  I use this.
Extend even further with these...
OnePlus Ecosystem:
3D Printing:
