Cs2 frame generation time issues.
Solved by jaslion,
1 hour ago, Eigenvektor said:I assume you mean frame times, not frame gen times. Most people would associate frame gen with DLSS FG or FSR FG. Or are you actually using frame gen?
Give Intel PresentMon a try and look at GPU Busy and CPU Busy. Given the low resolution and high frame rate, I suspect you're CPU limited. If you want a more consistent frame rate (and thus frame time) you'll likely need to limit your frame rate.
Also check gpu clocks. Was common in csgo but if the gpu had too low a load due to how easy the game was to run it would go into power saving mode and lower clocks affecting frametimes and framerates a bunch
