I I recently built my own PC but I have been having some problems with the lightings on the GPU and the sensors on the GPU. The integrated RGB on my graphics card isn't available anywhere. I have tried Signal RGB, the BIOS, and Polychrome but none of them detect the RGB. On the other hand, fan control can't see the GPU temps and sensors, while AMD Adrenaline and HWiNFO can see them perfectly. I wanted to put mixed curves in fan control but it doesn't pick up the GPU sensors. For now both my lighting and my fan curves are done through the BIOS, with my fan curves being set to only monitor the CPU as that's all my BIOS offers. Okay.
SPECS:
asrock steel legend rx 9070xt
asrock b850 livemixer wifi
windows 11 obv
https://linustechtips.com/topic/1633198-please-help-gpu-problems/
SPECS:
windows 11 obv
For fan control on GPU: Afterburner works great. Can even force firmware-level fan control.
As for the RGB: is it stuck on a single color, or is it rainbow vomit?
For the GPU RGB you probably need some ASRock app... good luck!
Otherwise I agree afterburner should be good for GPU fan control. Rest is done in BIOS. 👍
-Scott Manley, 2021
6 minutes ago, BiotechBen said:
That's what polychrome is
Ohhh 🤦‍♀️
Then maybe openRGB?
Although I didn't have luck with that and my Gigabyte RTX 5070... but it's already light blue how I wanted it anyway (hence whenever gigabyte changes their default RGB color I need to change GPU vendor, most likely 😬)
-Scott Manley, 2021
