Budget (including currency): 2000$-2200$CAD after tax
Country: Canada,
Games, programs or workloads that it will be used for: Mainly beamng, beammp, (programing, blender that is potentially)
Other details oh and my monitor is a tv that can do 4k 120hz (the tv was actually dead a couple of year ago but my dad did some : "gossage sa tv" then he hit the box and it became alive again, so bc the tv was sitting i chose to use it bc i had no monitor at that time lol) i was kinda stressed when i saw the cpu was not quite as good so i just remembered ltt has forum so there ya go my frend (not typo)
also i never FULLY built a pc but i know how to build one (i forogot to say i mainly play on 1080p)
Here the specs (also the cpu might be overkill but beamng is a cpu intensive game and that all other AVAILABLE cpu are meh)
Case AZZA CSAZ-370 FOREST Black ATX Mid Tower Case
motherboard :
MSI PRO PRO B550M-VC WIFI AM4 AMD B550 MATX AMD Motherboard
GPU : ASRock Challenger Radeon RX 9060 XT 16GB GDDR6 PCI Express 5.0 x16 Graphics Card RX9060XT CL 16GO RX 9060XT
PSU : CORSAIR RM750e (2025) Fully Modular Low-Noise ATX Power Supply with 12V-2x6 Cable – ATX 3.1 & PCIe 5.1 Compliant, Cybenetics Gold Efficiency, 105°C-Rated Capacitors, Modern Standby Mode – Black
CPU : AMD Ryzen 9 5900XT - Ryzen 9 5000 Series Vermeer (Zen 3) 16-Core 3.3 GHz Socket AM4 105W None Integrated Graphics Desktop CPU Processor - 100-100001581WOF
SSD : Crucial P310 M.2 2280 1TB PCI-Express 4.0 x4 NVMe 3D NAND Internal Solid State Drive Speed Up to 7100 MBps (SSD) CT1000P310SSD8
RAM : G.SKILL TridentZ RGB Series 32GB (2 x 16GB) 288-Pin PC RAM DDR4 3600 (PC4 28800) Desktop Memory Model F4-3600C18D-32GTZR
CPU Cooler : be quiet! Pure Rock Pro 3 120mm Rifle CPU Cooler Socket compatibility Intel 1851 / 1700 / 1200 / 1150 / 1151 / 1155 and AMD AM5 / AM4 - BK041
Note that im upgrading from 1070 8gb, 16 gb ddr3, i7-4770k (with stock intel cooler and yes it work perfectly), EVGA 650 (this was upgraded bc of the gpu) with external ssd (kingston i think)
Edited by MegaElite
removed useless info and changed the case
https://linustechtips.com/topic/1632612-need-help-for-new-pc/
DIYPC DIY-S07 is really meh it only has a 80mm fan in the back and cpu cooler is only mac 152mm
psu is at top so cables be a mess too.
be quiet! Pure Rock Pro 3 120mm is 155mm tall so wont fit.
Edited by thrasher_565
https://linustechtips.com/topic/1632612-need-help-for-new-pc/#findComment-16868121
