Is it worth upgrading from Intel HD Graphics 4600 to a Yeston RX 550 LP Single Slot 4GB in my 9020 SFF as it is the only card that fits in my budget, or should I wait till I can afford a Yeston RTX 3050 LP SS. I only need 60 FPS in CS:2 and the grunt for some light video editing , and CAD design. I have a Dell 9020 SFF with the 4x slot having a wifi card.
Thanks for your help!
CPU: Intel Xeon 1270 V3 E3
RAM:16GB DDR3 1600MHZ
STORAGE: Team force Vulcan 240GB SSD
PSU: 255W Dell Optiplex 9020 OEM Power Supply
Edited by OptiplexBuilt
Adding info
https://linustechtips.com/topic/1630260-gpu-help/
I'm a little confused as that CPU doesn't have an iGPU...
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1630260-gpu-help/#findComment-16851919
https://www.techpowerup.com/cpu-specs/xeon-e3-1270-v3.c1548
Yeah, every website I’m finding is saying the same thing…
MY PC: Ryzen 9 3900x | Asus Dual RTX 4070 OC | 128GB Kingston Fury DDR4-3600 Ram | 512GB 5000 mb/s TeamGroup M.2 NVME | 2TB + 1TB HDD (Western Digital | Thermalright Frozen Notte V2 360mm AIO | Hyte Y60 Snow White| Corsair HX1000 PSU |
https://linustechtips.com/topic/1630260-gpu-help/#findComment-16852049
Welcome to the forums!
That's essentially a i7-4770, you're probably gonna get some improvement, but not a ton. I'd cruise used sites for an old enterprise workstation with at least an i7-8700 before working on improving the GPU.
https://linustechtips.com/topic/1630260-gpu-help/#findComment-16852066
yeah if you could get an i7-8700 you could pair with a better gpu too
https://linustechtips.com/topic/1630260-gpu-help/#findComment-16852077
