Hi Guys,
First post here on tech tips.
I just finished a new build and I'm not happy with the temps.
Specs:
NZXT H440 Stock Fans
4770k
16GB Ram
MSI Z97 Gaming 7
500GB Samsung Evo SSD
Asus DirectCU GTX780
EVGA 650w Power Supply
Corsair h100i
At idle the cpu temps are around 34-40. Even if I crank the fans up it sticks around there.
When gaming I see temps of 60ish.
I noticed the rear exhaust fan at one point wasn't spinning and the center of the fan was super hot. I flicked the fan and its been spinning since.
I'm thinking the fans are kinda crap so looking for suggestions for the 3 front NZXT fans and the rear exhaust.
My only conditions are they must be black or black/red (color scheme) and not super noisy.
Any help greatly appreciated.
Thanks!
https://linustechtips.com/topic/162964-h440-cooling-suggestions/
Idle temps are pretty irrelevant. What are your load temps?
https://linustechtips.com/topic/162964-h440-cooling-suggestions/#findComment-2168474
Here's my temps after 5 mins of 100% OCCT load and corsair link set to performance mode.
http://imgur.com/n6pNTvb
I know thats not real world but I just play a few hours of smite and max temps were in the 60ish realm.
60c is perfectly fine. I wouldn't worry unless the temps were peaking at 80-90c.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/162964-h440-cooling-suggestions/#findComment-2168575
Hi Guys,
Specs:
4770k
16GB Ram
MSI Z97 Gaming 7
Corsair h100i
Thanks!
Although your temps are decent, it looks like you're unhappy with them. If price is no biggie I'd get 3 Noiseblocker BlackSilent Pro 120mm fans for the front intake. They perform as silent and good as Noctua's, are black and are static pressure optimized to push air well through the fan filters and harddrive cages of the H440.
They also have 140mm versions for the top and rear exhaust if you want to go full Noiseblockers. Here's a link http://www.blacknoise.com/en/products/it/10/Noiseblocker-NB_BlackSilent_Pro_120mm
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/162964-h440-cooling-suggestions/#findComment-2174566
those idle temps are hardly worrying, plus your load temps are still decent.
are your ambient temps really high?
you can get corsair fans if you're on a budget, otherwise noiseblockers?
edit: or bequiet fans
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/162964-h440-cooling-suggestions/#findComment-2175126
