Can not extend a partitiond USB stick
Solved by bradscoolio,
This should do the trick: http://files.extremeoverclocking.com/file.php?f=197
Source: http://forums.whirlpool.net.au/archive/1079317
I haven't used the tool above so be cautious, I use Rufus which I'm happy to vouch for. Maybe give this a try first: http://rufus.akeo.ie
Good luck :)
Stahlmann ·
Posted in Storage Devices1 -
crapnecks ·
Posted in Laptops and Pre-Built Systems1 -
4
epoke ·
Posted in Troubleshooting2 -
DannyTechTips ·
Posted in Troubleshooting1 -
tiwill0v2 ·
Posted in Power Supplies2 -
1
play_circle_filled
Latest From ShortCircuit:
I’m finally buying a new monitor - ASUS @ Computex 2024
