Hey folks so I've finally pulled the trigger on my new machine.
Core of the system will be:
  • 9800x3d
  • MSI B850 GAMING PLUS WIFI6E
  • MSI 5080 Inspire
  • Toughpower GF1 850 (porting from existing system)
  • 990Pro NVm 2tb
  • 2x HDDs
I'm really struggling with what case and cooler to go for, I'm very tempted by either of  meshify 3 / Lancool 217 but I can't make my mind up. So other suggestions would be great
I also have no idea what cooler I should pick up if I'm honest. (Perhaps Air over AIO?)
My requirements are basically top I/O (my pc sits on the floor) and as quiet as possible while still maximising performance.
So hive mind Please help me out
https://linustechtips.com/topic/1627548-case-and-cooler-recommendations/
  • 9800x3d
  • MSI 5080 Inspire
  • 990Pro NVm 2tb
  • 2x HDDs
If you aren't in the USA, you could get the Deepcool AK620 CPU cooler, but if you are in the USA, the Thermalright Peerless Assassin 120se is a good cooler.
  • 9800x3d
  • MSI 5080 Inspire
  • 990Pro NVm 2tb
  • 2x HDDs
Anything Fractal for case.  Note the North can only do a 360mm AIO in front, whereas the North XL can do one on top too.   Since you haven't decided on Cooler, wortth mentioning.  🙂
Realistically any decent cooler works, as the 9800X3D isn't hard to cool.  Better coolers can give you better OC if you want it, of course.  Though I think @Hinjima is using air to OC his 9800X3D.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Correct, I am using a DeepCool AK620 Digital at a constant 30% fanspeed to cool my 9800X3D running at 5.6Ghz ( up from 5.25Ghz stock ).
I use a Fractal Torrent case.
What about aesthetics, is the PC sitting somewhere where you can still admire from floor or is it chucked in some corner/under table?
UK
Each their own benefits, both can cool though, they differ in how they sound and how loud they get.
Thermalright Air
Thermalright Peerless Assassin 120 SE V3
Or Air But Spirit if you find it in stock and reasonable price
Thermalright Phantom Spirit 120 SE
Or AIO, 360mm from Thermalright
Thermalright Aqua Elite V3
or from ARCTIC
ARCTIC Liquid Freezer III Pro 360
current PC:
PC configs I used before:
UK
Thermalright Air
or from ARCTIC
true, but when an AIO goes bad and gets noisy because of the pump, you have to replace the entire unit.
When an air cooler goes bad and gets noisy, all you need to replace are the fans.
another point to consider.
https://www.antec.com/product/case/flux-se
https://www.tomshardware.com/pc-components/air-cooling/thermalright-royal-pretor-130-review
PCPartPicker Part List
CPU Cooler: *Thermalright Royal Pretor 130 81.88 CFM CPU Cooler  (£52.84 @ Amazon UK)
Case: *Antec FLUX SE ATX Mid Tower Case  (£89.99 @ Scan)
Total: £142.83
Generated by PCPartPicker 2025-11-28 15:10 GMT+0000
Total: £142.83
I ended up grabbing the royal pretor.
Still haven't chose a case. I may be able to use my meshify c in the mean time since the new gpu is only 3mm longer than my 3080 FE we'll see what happens
Mesh case means fans don't need to push air as hard to do the same job, which can be quieter too
current PC:
It's a great case I really like it. Pushes the boundries of how small an atx case can be which exactly what I want.
If the 5080 doesn't fit I'll have to upgrade to the meshify 3 I think or the  Lancool 217 with the cool infinity mirror because I'm a child at heart.
(Or rip a fan out of the meshify c in the meantime)
ATX probably means it can definitely fit ATX motherboard
GPU length support:
current PC:
