[ Moved to Networking ]
Does that same cable give you steady speeds if you plug it into a regular Gigabit port?
10 MB/sec sounds like Fast Ethernet (100 megabit) speeds, which could be a bad cable because 10/100 Ethernet only needs two pairs of wires in the cable to work.
https://linustechtips.com/topic/1626245-cable-or-box/#findComment-16823835
1 hour ago, whispous said:
Are you finding that big files get you to 1.5gbps and small files are slower?
First time i tried upgrading to 2.5 GB with a cheap switch, opened it up to see inside, and a small heatsink and a thermal pad to touch the metal casing, and this run is a
small transfers  with many 500mb video files
https://linustechtips.com/topic/1626245-cable-or-box/#findComment-16823873
2 hours ago, whispous said:
So what NIC/network card/motherboard are you using on both your pc and the NAS?
think it maybe more cable i redid the ISP coax line so i could have my 2.5gb switch with shorter Cat6 ( i hope cables that came with the router). cables, so two yellow ISP cat cables, one from the router for internet and the second one to my SSDNAS, and a outdoor cat 6 cable to my PC from the 2.5gb swtich box, seems to be more consitent than before writes
https://linustechtips.com/topic/1626245-cable-or-box/#findComment-16823967
just saw your post, thought it was the other person, and so far read speeds from the SSD NAS are at 15mb/s
https://linustechtips.com/topic/1626245-cable-or-box/#findComment-16823968
think i got the issue solved, redid the coax line for the ISP so the box is closer to my NASs and only have two 3-foot cat cables from the isp box to the 2.5gb swtich and a long cat6 cable to my main gaming pc, so far now its constant read and writes at 2.5gb with a Nas reboot eventually i will get a 10gb nic for my HDD Nas since its not much more expensive than a 2.5 gb nic
https://linustechtips.com/topic/1626245-cable-or-box/#findComment-16823981
