I haven't been hugely into tech for about 20 years, but I have been watching LTT and WAN show religiously for about 4 years.  I am thinking its time to invest into a real pc and better computer literacy.
If I get a new pc I plan to build my own.  My biggest likely uses would be learning CAD and offline RTS gaming.  My only extra space in my home is occupied by my wife's office which is why I would prefer to use this set up primarily in my living room on my existing 55 inch tv.  My tv is 80 dpi, I would plan on using a wired connection to the tv.  I am not at all worried about the ability to physically build the computer.  I plan to first learn what will work and work for me, then build a budget.
Would latency on wireless peripherals from 7-10 feet be particularly annoying?  I am not particularly picky about this stuff but I would be bothered by moderate to harsh latency
Without bothering to look stuff up for me what would you guess a reasonable set up like this would cost in usd?  Building myself, all new components, no case needed.
Bearing in mind I am looking for a comfortable experience here not an exceptional one am I out of my mind for even trying to get away with an across the (short) living room set up here?
https://linustechtips.com/topic/1625302-cad-rig-wireless-paripherals-crazy/
Almost any reputable brand of wireless peripherals will operate at such low latency it will be indiscernible  from wired.
What CAD software are you wanting to learn? It would have a big impact on where you should spend money for the best experience without dropping a lot of money. I've been working in commercial architecture using both CAD and architectural modeling software, and have built nearly all the office workstations throughout that time.
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
I expect to use solid works.  I want to learn as a hobby and don't expect be creating ultra complex 3d models any time soon.  Mostly modeling furniture I intend to build for my wife.  That being said I do build trailers for a living (think travel trailer but simpler) and being able to move into the design side with my own employer or any other would be a career move I may go after if I take to cad.  So I do want to learn a system that could translate into a professional world later.
You’re going to want 32GB of ram for Solidworks, the video card will be less important but it will impact your experience if you go too low-end.
PCPartPicker Part List: https://pcpartpicker.com/list/xfGch7
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($265.00 @ Amazon)
CPU Cooler: Thermalright Assassin X 120 Refined SE 66.17 CFM CPU Cooler  ($17.89 @ Amazon)
Motherboard: ASRock B850M Pro-A WiFi Micro ATX AM5 Motherboard  ($119.99 @ Amazon)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($139.99 @ B&H)
Storage: Crucial P310 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($124.99 @ B&H)
Video Card: PowerColor Reaper Radeon RX 9060 XT 16 GB Video Card  ($349.99 @ Amazon)
Case: NZXT H3 Flow MicroATX Mid Tower Case  ($59.98 @ Newegg)
Power Supply: Cooler Master MWE GOLD 750 V2 FULL MODULAR 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($88.99 @ Newegg)
Total: $1166.82
Generated by PCPartPicker 2025-10-25 12:16 EDT-0400
AMD Ryzen 5900X
EVGA RTX 3060 Ti XC
WD 5400RPM 2TB
EVGA G3 750W
