37 minutes ago, martinwest said:
i did downloaded installed it and nothing no realtek driver
Check the BIOS to confirm Audio chip is not disabled...
Audio Inputs and Outputs is listing your monitor.
If Device Manager cannot see the Realtek chip, it could be bricked, if the BIOS shows it as "Enabled".
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1624637-no-audio-driver/#findComment-16812260
its enabled in bios
ind device manager its greyed out when i click of "show hidden devices"
https://linustechtips.com/topic/1624637-no-audio-driver/#findComment-16812281
3 minutes ago, martinwest said:
its enabled in bios
Can you 'unhide' it, if you right click "Realtek(R) Audio"...?
Hidden Devices will be the issue; are you using HDMI to your monitor... or Dp??
WHY NOT...?!
https://linustechtips.com/topic/1624637-no-audio-driver/#findComment-16812285
i can only update/uninstall and when i update it nothing happens
i am using a DP
https://linustechtips.com/topic/1624637-no-audio-driver/#findComment-16812292
