Was surfing around the RSI forums and found this.
https://forums.robertsspaceindustries.com/discussion/110454/guide-actionmap-and-controller-mapping/p1
it's a very interesting read, and may be of use to some of us.
Another control possibility is: https://forums.robertsspaceindustries.com/discussion/141313/voiceattack-voice-commands-for-arena-commander-where-to-find-it-how-to-and-example-of-use#latest
It's a voice to command program. I am still in testing with it, but it seems to work, other than thinking I am saying ten when I say pin
https://linustechtips.com/topic/162439-rebinding-and-custom-controls/
Hey there:
This is great stuff !  Anyway to add a rudder to the xml editor ?  I currently use a Thrustmaster Hotas Warthog and would like to include my Saitek rudders in my control mix. (As an ole aviator, I like to use my feet to control yaw.)  Thanks.
Yippe ki yay
Yippee-ki-yay
As for now there's much more stuff mapped to keyboard than any of the sticks.
I'll try mapping those keyboard functions to my x-55 using the saitek's software and see how that works. Maybe I'll be able to switch roll with yaw by mapping them through mouse axis...
If any of that works I'll post something here.
peace
there are profiles being built by the community,
so Yes cowboy you can, there is a file for that, I think it's in the third or fourth post.
Maciek, more commands will be brought avalible for rebinding to joysticks as CIG adds them to default profiles, sadly mapping them isn't possible yet. IE if not in the default, can't be rebound just yet.
I did find another thread about using a voice control software for some of the more annoying stuff. have added it to the OP, but I am still testing it and have not used it enough to provide a positive or negative for it
