So this will sound crazy but my computers audio speakers,headphones ect do not work its does not output audio in game youtube or anywhere its been 1 YEAR like bruh. The story starts a year ago I had old speaker they where working fine but they looked ugly I bought new prettier speakers they worked for like 6 months then the left side did not produce audio I didn't care that much but then after 4 months the right side also stopped working I tryed updating drivers and resetting sound setting nothing worked also it says the speakers are connect and the volume knob shows up in windows but no sound I put it at 100 percent still not sound my motherboard is a b450m hdv now a month ago my front case audio ports started failed headphones do not work anymore I have a new motherboard bought it this year still no sound I tryed my old speakers the ugly ones those also didn't work on my pc or my new pc no sound I tested the speakers both old and new with my phone they output sound fine but on my pc they do not output any I tryed different playback devices still no use I tryed reinstalling the drivers and that also did not work what do I do now? I can't buy new speakers what if those also do not work PLEASE SOMEONE HELP
https://linustechtips.com/topic/1623735-audio-does-not-work/
1 hour ago, Cheesewad said:
All these pictures are took while my speakers do not work
Have you tried all of the ports just to see if the main speaker port is fried?
A quick and dirty solution is to get the apple usb-c dongle. It is probably the cheapest DAC that you can buy.
https://linustechtips.com/topic/1623735-audio-does-not-work/#findComment-16806046
I tryed all of them none work not even the motherboard ones
https://linustechtips.com/topic/1623735-audio-does-not-work/#findComment-16806651
