Hello, everyone!
I'm looking to upgrade my GPU from a very old GTX 960 2GB, since it will stop receiving driver updates starting next month.
I'm not a huge gamer, but I’d still like to try out some of the heavier titles I missed over the past few years.
Examples: Red Dead Redemption (both of them), Cyberpunk 2077, Silent Hill 2 and Silent Hill f, Resident Evil Village, and Resident Evil Requiem.
My current setup:
  • CPU: Ryzen 5 5600X
  • RAM: 16GB (2×8 GB) DDR4 3200 MHz (considering upgrading to 32GB)
  • OS: Windows 11
  • PSU: 650W (I know I might need to upgrade)
  • Displays: 43" 4K TCL 43P635 & LG UltraGear 24GL600F-B
What I hope to achieve with this upgrade is longevity. As you can imagine, I’ve been using my GTX 960 since its release, and I’ve milked it for all it’s worth.
I’m set on switching to AMD and would like to play cinematic games in 4K on the TCL, while using the LG UltraGear for more casual/competitive titles.
The options I have in mind are the RX 7900 XT (I’ve seen some pretty good deals on it, though it’s a slightly older card) and the RX 9070 XT (since it’s newer, it might last longer in terms of support and performance).
The price difference is significant, but I’m willing to pay extra for something that will last longer.
Do you think I’m making the right choice given my current hardware, or would you recommend a different direction?
As for the GPU, I’m sticking with AMD and don’t plan to change that.
I appreciate the input and time that took to considering answering my post.
https://linustechtips.com/topic/1623733-advice-for-upgrade/
7 minutes ago, snyte said:
Hello, everyone!
My current setup:
  • OS: Windows 11
The 9070's a good card but it would greatly benefit from a newer CPU as well. Maybe consider a cpu from Intel's Core Ultra Lineup or from AMDs 9000 series processors. Nothing wrong with just upgrading the gpu but a cpu upgrade would go a long way. But the games you've listed should run alright with the 5600.
https://linustechtips.com/topic/1623733-advice-for-upgrade/#findComment-16806019
While I completely agree that a CPU upgrade would be very good, I intend to do a gradual upgrade of my current system. And because of that, I believe the GPU is a top priority.
https://linustechtips.com/topic/1623733-advice-for-upgrade/#findComment-16806033
Milking something is neat but while you can pat yourself on the back for your 960... You missed out on some amazing games cuz it can't play them.
Longevity is good if you are cash strapped perpetually.
But I would prefer a good 4-5 year cycle that allows you to slowly reduce settings to keep the gpu relevant.
For example, dropping in a 9060xt 16gb would give you that.   For only $380.  More is better but that's the cheapest id go.
Replace it in 5 years and keep enjoying anything that comes out.
Unless you really enjoy when your friends tell you how awesome borderlands 4 is while you can't play it 👍. (For example)
Life is too short.  Enjoy it!
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1623733-advice-for-upgrade/#findComment-16806045
Welcome to the LTT forums! I am going to go against the other posters since you have a 4K display, and say that you should be fine with that upgrade, sure I would like it if you had at least a 5700x, but you should still be able to push both the 9070XT and the 7900XT pretty hard. I personally would go for the 7900xt if you plan on buying a PSU anyway.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
https://linustechtips.com/topic/1623733-advice-for-upgrade/#findComment-16806095
Then the 9070xt should serve you well. 7900xt slightly loses out to the 9070 but it has a bit more vram but "lacks" fsr4 tho a bit of tinkering should get that sorted if you decide to go that route. And yes, you will need the upgrade since a 700W PSU is recommended.
https://linustechtips.com/topic/1623733-advice-for-upgrade/#findComment-16806152
Yeah, I did miss a couple of games because of my very late upgrade, but as I said in the original post I'm not that big of a gamer always looking for the new releases.
I might have given that impression when the examples I gave were recent, but that was to illustrate the absolute maximum I would try to extract from that upgrade.
The reason I don't upgrade more often is that, personally, I'm fine letting some stuff pass, not because I enjoy it, but simply because I have some other priorities.
I'm going to consider the 9060 XT.
Thanks for your insights!
Thanks for the warm welcome. Yeah, the PSU sounds like it's going to be a necessary upgrade since I intend to jump to this mid-range card, so I don't mind adding that to the expenses. Thanks for your input!
I completely forgot about FSR! You're right! From what I can tell 16 GB of VRAM should be plenty to play the games I want natively and with FSR I should be able to push the hardware a little further! Thanks for you answer!
https://linustechtips.com/topic/1623733-advice-for-upgrade/#findComment-16806302
