UNRAID Drive Failure Advice
Go to solution Solved by OddOod,
There is a plugin called unBALANCE which will level the distribution in your array
Hi guys,
One of my 4TB drives in  my UNRAID array as moved from having a single SMART error that I've been nursing for a while now with no issues however, a couple of days ago I started getting more errors so now I want to look at getting the data off that drive.
While I could go ahead and buy an new drive and go through the steps of rebuilding the data from parity, I've got plenty of space on the other drives so wanted to know how to shift / reallocate the data currently stored on the failing drive onto the other drives.
My intention would be to empty the faulty drive then just remove it from the array.
Thx
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1623531-unraid-drive-failure-advice/
I have wondered the same before and looked up guides. Unfortunately they don't seem to have a one button script to do it. There are a multiple versions of ways to do this you can look up and try. Some preserve parity, some don't so require a rebuild. I never did it in the end because I thought the risk of me making a mistake and losing data was not worth it. I'm just waiting for a specific drive to be at the right price before I wholesale replace a bunch. It might just be easier to get a replacement drive as swapping and rebuilding is easy.
Thanks buddy,
I've just found unBALANCE now and it looks like it does what I need.
The only issue I'm finding with it is its doesn't appear to 'Scatter' all the data on the source drive to all other drives even if there's enough space.
Unless I'm missing something, I'm currently selecting xyzTB of data then moving it to a single drive with at least that free. Once that drive fills up, I repeat with another selection of folders and move them to the next drive. Rinse and repeat!
Anyhoo, this seems to be working and Parity appears to be rewriting as this progresses so fingers crossed I'll have everything off this drive by tomorrow and I just remove the offending drive from the array.
I think you want this section of the unraid docs
https://docs.unraid.net/unraid-os/using-unraid-to/manage-storage/array-configuration/#removing-data-disks
Thanks.
I did a bit of Googling earlier on this.
Am I right or wrong in thinking, a parity rebuild after a drive has been removed due to failure requires another new drive to be installed in its place?
I think that's what Google was telling me so that's why I'm just moving the data and allowing parity to be rewritten so I don't need to fork out for another drive.
I'm sure someone on Reddit had asked a similar question in the hope he could just yoink the offending drive, do a parity rebuild and have it redistribute the recovered data across the remaining drives but the answer appeared to be no.
You are correct. But if you follow the steps they lay out, step 4 will let the system know that it needs to rebuild parity ignoring that drive
15 hours ago, OddOod said:
Looking at that again reminds me why I didn't go ahead with my own disk removal. That standard process leaves you without parity until you rebuild it. The advanced parity preserving method, if you make a typo things can go bad fast.
If you replace the drive, you're rebuilding the data on the replaced drive, not rebuilding parity information itself.
If you don't replace the drive, you need to rebuild the parity data unless you zero'd the outgoing drive while it was in the array to keep the parity data correct.
In theory it might not be impossible, but it would be complicated to implement and risky. Better to do the existing documented methods.
Think about the steps involved. You'd still have to create the virtual failed drive using parity data and remaining drive data. Then you move data off that virtual disk onto real disks, updating parity as you go. Only when you've moved all data off, you can zero out the virtual disk and remove it.
