Network wiring speed question
Go to solution Solved by Ron30,
Got a cabler in. One wire was broken, so had to run a new cable through.
So I'm running an Asus ZenWifi AX (XT8) system with 1 main router and 1 mesh node. My current setup is as follows.
The Fibre Modem is connected to the 2.5G WAN port on the primary router with a Cat 5e cable, and shows in the Asus app as a 1 Gbps connection.
Port 1 on the primary router goes to the wall with a Cat 6 cable, but shows as a 100 Mbps connection.
The wall goes to the 2.5G WAN port on the mesh node with a Cat 5e cable, and shows as a 1 Gbps connection.
Port 1  on the mesh node goes to my desktop PC with a Cat 5e cable, and shows as a 1 Gbps connection. Windows also shows a link speed of 1000/1000.
Port 2 on the mesh node goes to an unmanaged switch with a Cat 5e cable, and shows as a 1 Gbps connection.
All devices, except WIFI devices on the other end of the house, are connected to the mesh node, not the primary router. Anything connected to the primary router is getting my full internet speed in speed tests, but anything connected to the mesh node; wired or wireless, are being capped at 100 Mbps. Would this indicate that the wiring inside my walls is only Cat 5?
Previous PC:
CPU: AMD Ryzen 9 5900X Motherboard: X570 Aorus Pro WiFi RAM: 4x8GB DDR4 G.Skill Trident Z 3200Mhz CL16 GPU: ASUS TUF Gaming GeForce RTX 4070 Ti Case: Cooler Master MasterCase H500M PSU: Corsair AX860 860W / CPU Cooler: EK-Quantum Velocity D-RGB / GPU Cooler: Bykski 470 Ti Waterblock Pump: EK-XRES 140 Revo D5 RGB Radiators: 2x EK Coolstream PE 360 Fans: 6x Corsair ML120 Magnetic Levitation fans Storage: Samsung 970 EVO 500GB NVMe + Samsung 970 EVO 2TB NVme NAS: Synology Diskstation DS920+ with 4x Seagate ST4000VN008 4TB IronWolf 3.5" NAS HDD Monitor: Alienware AW3423DWF 34" 166hz 3440x1440 Curved QD-OLED Keyboard: Logitech G915 Mouse: Logitech MX Master 3 Additional RGB: 4x Corsair LED strips
Current PC:
CPU: AMD Ryzen 9 9950X3D Motherboard: X870 Aorus Elite WiFi 7 ICE RAM: 2x32GB DDR5 Silicon Power XPOWER STORM RGB 6000Mhz CL30 GPU: MSI RTX 5080 Ventus 3X OC Case: Lian Li O11 Dynamic EVO XL White PSU: Corsair HX1200i 1200W CPU Cooler: Alphacool Core 1 Aurora White GPU Cooler: Alphacool Core 5080 Reference Waterblock Pump: Alphacool Rise Flat Reservoir D5 with VPP Apex Pump/Res combo Radiators: 2x EK Quantum Surface P-360M X-Flow Fans: 9x Lian Li 120mm Unifan TL + 3x Lian Li 120mm Unifan TL LCD + 2x Lian Li 140mm Unifan TL Storage: Crucial T700 PCIe5 1TB NVMe + Crucial T700 PCIe5 2TB NVme NAS: Synology Diskstation DS920+ with 4x Seagate ST4000VN008 4TB IronWolf 3.5" NAS HDD Monitor: Alienware AW3423DWF 34" 166hz 3440x1440 Curved QD-OLED Keyboard: Logitech G915 Mouse: Logitech MX Master 3 Additional RGB: Lian Li 24 pin Strimer Cable + Lian Li 12v2x6 Strimer Cable
https://linustechtips.com/topic/1622808-network-wiring-speed-question/
That would be the logical guess and what I would look into first. An easy test would be to try and bypass the wall. Take the mesh node and hook it directly up to the router. It should show 1gb.
Also, pull the wall plate off. Are all 8 wires in the plug ot only 4? For 100mb/s you only use 4 of the 8 and in the past, lazy installers often didn't bother to crimp all 8..
To add to what @Blue4130 said, you migt just have a bad connection in there some where.  I know I use keystones in my wall and they can look punched down but not make connection. So a cable tester can be handy.
So I plugged a mini PC into the primary router with a Cat 6 and got a 1 Gbps connection.
So if primary router to wall port shows as 100 Mbps, but at the other end, wall port to mesh node router shows as 1 Gbps, would that indicate that it's terminated correctly on one end but not the other. I'm almost certain this is a single cable connecting both ends of the wall ports.
Previous PC:
Current PC:
Found my network tester. Looks like I'm getting signal from 7 of the 8 pins, so may just need to be crimped again.
Previous PC:
Current PC:
This is why I always keep an extra 30cm of cable on each end of my cable runs. Eventually I'm gonna need to repunch
  • 4 weeks later...
Previous PC:
Current PC:
