 I hesitate between the following 2 (same price in my region):
 - Gigabyte Aorus Elite Wifi 7 Ice (DP only, better USB-C, better look, internal HDMI)
 - Gigabyte Eagle Wifi 7 Ice ( DP+HDMI, better secondary PCIe slot)
Let me know if I missed another key difference.
Which one is your favorite? Why?
Thanks 🙂
-a-
https://linustechtips.com/topic/1622799-aorus-elite-or-eagle/
Depends on what you need/value.
For example, for me personally:
  • Looks: Irrelevant, its a motherboard, not an art piece
  • DP/HDMI: Irrelevant, I use a discrete GPU
  • Better secondary PCIe slot: Irrelevant, I only need one PCIe x16
My pick would be the Aorus because of USB ports, more NVMe slots, more fan headers.
(If I was limited to these two, I'd probably pick something else entirely otherwise)
https://linustechtips.com/topic/1622799-aorus-elite-or-eagle/#findComment-16799977
