I'm looking for a braided micro USB cable to replace the standard cable for my keyboard. What I'd really like is something close to what Razer is using for their mouse cords. It's a much tighter weave and doesn't retain kinks as much as a standard braided cable would, such as Corsair's in this example. Has anyone found this type of cable? I've seen a few colored ones, but most braided cables seem to be of the looser weave variety.
https://linustechtips.com/topic/162273-tightly-braided-usb-cables/
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
What @Luc401 said. You'll have to sleeve the cable or make a custom cable. Both are easy methods if you have the necessary skill. And it's easy to learn
The year is 20XX. Everyone plays Fox at TAS levels of perfection. Because of this, the winner of a match depends solely on port priority. The RPS metagame has evolved to ridiculous levels due to it being the only remaining factor to decide matches.
Only Abate, Axe, and Wobbles can save us.
Well you could try to find one with some searching. Or have someone do it for you. Good luck though!
