Actually GOOD audio extractor
Go to solution Solved by Kilrah,
Avidemux
I am looking for a program that will take the audio from videos and save it as a separate file or encode as mp3/wav. "Just Google it"? I tried doing so but every site I could find was an advertisement disguised as an article leading you to download a software with a free trial, limited features in the free version, watermarks on audio etc. I don't want this. I also don't want to use online converters because that takes much longer especially for large video files.
I want a program that was made in 2003 over a time span of 6 hours by one guy and has never been updated since. One which does its one intended purpose flawlessly and does nothing else while using 985kb of hard drive space.
Does a program like this exist?
Thanks!
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1621613-actually-good-audio-extractor/
https://github.com/Bisalkumar/Audio-Extractor
Avidemux
F@H
GPD Win 2
Another vote for FFMPEG. I use Linux, and their are tons of GUI front ends for it. So I just dump all the videos in the one I use, tell it what bit rate I want, and where to put the files (and what to convert them to), and it spits out the new files. Couple clicks and done, quick and easy.
4 minutes ago, Kilrah said:
Avidemux
Oh, forgot you could set video output to null. Thanks!
Works Cited
MeGUI - https://sourceforge.net/projects/megui/  - has a HD Streams Extractor in the menu, it uses various tools (depending on the video and audio format) to extract the audio without recompression, or if you chose with recompression to another format (for example convert 7.1 to stereo)
MKVExtract GUI - https://sourceforge.net/projects/gmkvextractgui/ -  can be used in combination with MKVToolnix - https://mkvtoolnix.download/downloads.html -  to extract streams from MKV files  - the first is a graphical interface that shows you the streams inside a MKV file, and can extract them using MKVtoolnix
or audio->save audio track (it'll take the audio settings so you can copy or convert)
F@H
GPD Win 2
