Hello. I have the following PC:
CPU: AMD Ryzen 7 7700
CPU Cooler: ID-Cooling Frozr A620 Pro SE, Arctic Cooling MX6 thermal paste
MB: Gigabyte B650 Gaming X rev 1.3
RAM: 2x16GB DDR5 6000MHz
GPU: Gigabyte RTX3060 12GB Windforce OC
SSD: 1x500GB for OS (M.2), 1x1TB for games (M.2)
HDD: 1x512GB S-ata3
PSU: Seasonic 650W semi modular, 80+ gold
PC Case: Redragon Scalpel Black (dual chamber)
Fans: 2x140mm intake, 2x120mm exhaust.
I use HWinfo for monitoring.
The problem is as follows:
I got about a maximum of 85*C - 88*C on the CPU while gaming Stalker 2 Heart of Chornobyl. The temperature of the room where I play games is about 29-30 degrees Celsius.
While idling the temperature is at a minimum of 36*C
My question is:
Is the CPU mentioned temperature (85*C-88*C) normal while gaming ?
https://linustechtips.com/topic/1620657-cpu-cooling/
HDD: 1x512GB S-ata3
My question is:
Yes, the newer Ryzen CPUs are meant to ramp up and provide as much performance as cooling allows.  Even with a 360mm AIO my 7700X would hit low 80's even with PBO/CO undervolt.
If you throw more cooling at it, it'll just hit those temps again but perform a little better.
All is as it should be.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1620657-cpu-cooling/#findComment-16785162
HDD: 1x512GB S-ata3
My question is:
The temperatures are fine for a Air Cooler and Ambient temps on an AM5 CPU. They run considerably hotter than the AM4 counterparts.
You can set custom negative PBO curves to lower the temperatures a bit or like me turn on Eco Mode+negative PBO Offset. It will lower the performance a bit but won't be noticeable by much in some games. For me temps went to 65-70C from 80C and CPU voltage never exceeds 1.29V which on auto reached as high as 1.47V
CPU: Ryzen 7 5700X Undervolted  Motherboard: B550 Aorus Elite V2 Rev1.2 RAM: G.Skill TridentZ Neo 3600Mhz CL16 32gb
GPU: MSI Mech 2X RX6600 8GB Cooler: ProLab Design AI360 LC AIO Storage: WD SN770 500gb + Sn550 1Tb + MX500 1Tb + 1TB HDD
PSU: Antec EAG Pro 750 80+G Case: Deepcool CG580 WH Monitor: Benq Mobiuz EX2510 144Hz
Mouse: G Pro Wireless Keyboard: Corsair K68 RGB Cherry MX Red Speakers: Creative Pebble V2
https://linustechtips.com/topic/1620657-cpu-cooling/#findComment-16785169
They run a little warmer because they are running about 1-1.5GHz faster than Zen 3 😄
These are high performance CPU's that demand the best in cooling.
My 9900X can hit 300w with just a PPT/TDC/EDC tune in conjunction with boost override and my curve.. no scalar.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1620657-cpu-cooling/#findComment-16785233
2 minutes ago, beard49 said:
I set a negative CO (Curve Optimizer) of 20 and a thermal throttle limit of 88.
Now I have a maximum temperature of about 80 *C while gaming.
Great temp for gaming.  Well done.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1620657-cpu-cooling/#findComment-16785674
I would just let it run up to its redline, it will stay there. When you cap the temp yourself in the bios, you are also taking some performance off of the table. Maybe try to work on your case flow. I am not really a fan of ID cooling.
https://linustechtips.com/topic/1620657-cpu-cooling/#findComment-16785797
Games are easy for a CPU. Nothing to see here.. carry on.
https://linustechtips.com/topic/1620657-cpu-cooling/#findComment-16787126
if ambient temp is 30c and cpu temp is 85c then it would be 75c with an ambient temp of 20c so all is good.
https://linustechtips.com/topic/1620657-cpu-cooling/#findComment-16787290
On 8/22/2025 at 12:54 AM, KLiKzg said:
Well, when I have 30°C inside the home (usually it is up to 28°C), then my CPU is up to 65°C the most!
Why?
Oversized cooler.
How?
Double the W of cooler, compared to CPU TDP.
Example:
On my 130W dual CPUs I have 240W & 270W coolers. 😎
what cpu? what gpu? what case?
is that 65c gaming?
https://linustechtips.com/topic/1620657-cpu-cooling/#findComment-16788405
