ARGB do I need a second cable
Go to solution Solved by Poinkachu,
47 minutes ago, james8449834 said:
Hello,
I have just found out the solution to getting my graphics card to talk to signal. And that requires me to plug a cable flick a switch.
Yesterday I ordered a ARGB bar that omes with a splitter will I be able to use the splitter instead. I do have 2 free ARGB headers.
As long there's no funny business with how the RGB on the GPU was set-up, you can use the splitter.
Hello,
https://linustechtips.com/topic/1618247-argb-do-i-need-a-second-cable/
Hello,
Refresh before you reply
