Thermal paste everywhere help please
Go to solution Solved by CasualExtremist,
After processing the images and controlling my breathing, my first real thought is an extremely soft bristled brush and isopropyl alcohol. You'll want a few ROLLS of paper towels at hand so that when the alcohol starts mixing with the thermal paste and trying to run/flow into new areas of the board, you can gently wipe it up to prevent it spreading the thermal paste further. I'd go gentle and slow to the best of my ability, but as long as you have enough time, definitely fixable.
Edit: If you know any women or if any are nearby, ask if they have a makeup brush you can destroy. Those are typically very soft bristles. Just make sure you give it a dry brushing on your hand or elsewhere to shake off any loose bristles before using on the electronics.
So I came to help a buddy who said he built his computer with an uncle or something. I get here they say is this bad and this is what I’m looking at. Now from experience with older boards you could possibly fix this issue. We are not too worried about the board tbh he can buy a new one it’s the CPU that we are more worried about. Any help would be greatly appreciated
https://linustechtips.com/topic/1617291-thermal-paste-everywhere-help-please/
Both should be salvageable with enough isopropyl. The CPU just looks ugly, with a single wipe of the pin contacts odds are it'll just work. The motherboard is the one that's a bit sketchy, but flushing out the socket with isopropyl enough times should hopefully pix it assuming no pins were bent in the process.
Dreaming of the day when my brain cell doesn't betray me.
The CPU is gonna be fine. You could dunk it in a tub of thermal paste, leave it overnight, and once it's cleaned off with rubbing alcohol it'll be just fine. Heck, if you dropped it into a jar of peanut butter, I'd be more concerned that it contaminated the peanut butter than that the CPU was hurt.
The board is the real concern. Do you know if that paste is conductive? What paste did they use?
If you go the makeup brush route, make sure it isnt a used one btw. Just thought about that 🤦‍♂️
How tf did you manage to do that??
Anyway paste isn't conductive so a good cleanup will be enough
Do you have 99% IPA?
current PC:
PC configs I used before:
To be honest soaking the CPU in 99% isopropyl alcohol would most likely be fine and using a toothbrush (also soaked in isopropyl alcohol) will do the job!
21 minutes ago, emosun said:
wasn't there a video showing thermal paste can actually be in the socket and have no effect due to being non conductive electrically?
doesn't it actually depend on the thermal paste used?
Sadly some of the best performing are also electrically conductive.
Are they using the AM4 mounting hardware on an AM5 motherboard?  Hope it's the same.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
It generally is. It's compatible as long as it uses the stock backplate, which that hardware appears to use.
If it used the mounting clips, there are compatible coolers from all the way back to the AM2 days. AMD's backwards compatibility for coolers is kinda insane.
presuming they didnt find that one type of paste that is still conductive these days, this isnt that much of a "disaster" past just a ridiculous mess to clean up.
for the socket the procedure is just to rinse, i wouldnt stick anything in there that doesnt belong there if you arent absolutely 100% sure what you're doing. buy one of those spray cans of 99% isopropyl alcohol. ever since covid they have been rather expensive, but that will be a fairly safe method to clean the crud out the socket.
as for the cpu.. i'd do the majority of that mess just with kitchen tissues, then a once-over with isopropyl.
but if it's a matter of getting it to work and screw the mess.. just put the cpu in the socket, if you're missing a memory channel or something you just open and close the socket a few times until all the crud is out the way of the pins.
also, protip, if you go for the alcohol rinse of the socket, hold the motherboard upside down above a surface you dont mind getting dirty, then the crud just falls straight out instead of all over the board.
Everyone here has great advice, both cpu and board will be fine, I usually use a very soft tooth brush and isopropyl alcohol, for the board you can lightly poor it in the socket then stand the board up side ways to knock the bulk of the paste out.
okay i got an update! cleaned everything up best i could now i got red CPU light and Yellow DRAM light on the board, ive tried CMOS batt reset ive tried the flash BIOS button on this board ive tried to see if the cpu had damaged the pins everything seems fine i checked power cables im at a loss he's about to order a new board and new CPU but i told him id come here first for any ideas. any help would be great
The link is the build parts that are the ones in question.
https://pcpartpicker.com/list/RDrrfd
23 hours ago, Shinyvids said:
my other question is can you try to boot the PC up without the cooler on there? for like long enough to see a boot screen then kill it? im trying to see if the seating is an issue but taking the cooler on and off is a pain.
Worth reiterating the advice previously stated. Seems like you're headed that direction, but
As far as boot testing with no cooler, this forum topic might be of help:
