Help me optimize my part list
Go to solution Solved by Why_Me,
18 minutes ago, Jeuca said:
Thank you for the reply but will 12GB of VRAM be enough (i dont care much about Ray Tracing so I went with an AMD GPU) and since your reccomended build has some budget left to spend should i go with an AIO as my CPU cooler (water cooling thing i think its called like that) also i saw theres a problem with asus motherboards and this specific cpu catching on fire is that a very common occurance or just factory defect?
12GB of VRAM for 1080P is fine, not to mention Nvidia performs well with Solidworks. The Asus boards overvolting was over a year ago and that was fixed with a bios update.
Here's a board with better VRM's than that Asus board I linked and it also supports PCIe 5.0 for the video card.
https://geizhals.eu/msi-pro-b850-p-wifi-7e56-002r-a3383519.html
MSI PRO B850-P WIFI €176,90
Budget (including currency): ~1500€ (up to 2000 but id prefer to keep it around 1500)
Country: Slovenia
Games, programs or workloads that it will be used for: Solidworks, CS2, Some modern games mostly games from FromSoftware (at medium settings atleast) (In 1080p)
Other details:
https://pcpartpicker.com/list/RL9zdb
Hello, could anyone help me optimize my PC parts or check if the motherboard is suitable for this build. I will be ordering parts from MindFactory but they dont ship to Slovenia so I'd have to use an agent, does anyone have any experience with that? I'm pretty new to computer building. I'm upgrading from an HP Omen with an I7-7850H and a GTX 1060 3gb. I honeslty mostly need it for CS2 but i also want it to future-proof it as much as possible so in case a game i like comes out in the future i could play it. Is this an overkill? Should i downgrade to an RX 9060XT? (Sorry for my broken english playing CS2 in Europe hinders your ability to speak proper English)
Thank you in advance.
https://linustechtips.com/topic/1616581-help-me-optimize-my-part-list/
@Jeuca you want DDR5-6000 CL30. This gives you both a board and gpu that support PCIe 5.0. I have no experience using an agent but I do know there are shipping services in Germany that people use. Also try Amazon.de, Computer Universe, Alza, etc ...
https://geizhals.eu/asus-b650e-max-gaming-wifi-90mb1ld0-m0eay0-a3417117.html
ASUS B650E Max Gaming WIFI €160,89
https://www.amazon.de/-/en/AMD-Ryzen-7800X3D-Technology-Integrated/dp/B0BTZB7F88/
AMD Ryzen 7 7800X3D €318.49
https://geizhals.eu/id-cooling-frozn-a620-pro-se-a3228637.html
ID-COOLING FROZN A620 PRO SE €31,90
https://geizhals.eu/patriot-viper-venom-rgb-dimm-32gb-pvv532g600c30k-a3204206.html
Patriot Viper Venom DDR5-6000 32GB (2x16GB) CL30 €92,89
https://geizhals.eu/patriot-p400-lite-2tb-p400lp2kgm28h-a2892158.html
Patriot P400 Lite 2TB M.2 PCIe 4.0 x4 NVMe SSD €98,89
https://geizhals.eu/asus-prime-geforce-rtx-5070-a3382475.html
ASUS Prime GeForce RTX 5070 12GB €540,04
https://geizhals.eu/adata-xpg-core-reactor-ii-ve-750w-atx-3-1-corereactoriive750g-bkceu-a3167580.html
ADATA XPG Core Reactor II VE 750W ATX 3.1 €86,89
https://geizhals.eu/montech-air-903-base-black-a2974660.html
Montech AIR 903 BASE €52,64
Total: €1382,73
Country: Slovenia
Other details:
Faster RAM, better GPU, 4TB of NVme storage, 1800EUR in Germany
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (€379.00 @ Amazon Deutschland)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  (€43.89 @ Proshop)
Motherboard: Gigabyte B650M GAMING PLUS WIFI Micro ATX AM5 Motherboard  (€131.90 @ Amazon Deutschland)
Memory: G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€129.89 @ Alternate)
Storage: TEAMGROUP MP44 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€233.89 @ Alternate)
Video Card: ASRock Challenger Radeon RX 9070 16 GB Video Card  (€648.90 @ Mindfactory)
Case: Fractal Design Meshify C ATX Mid Tower Case  (€101.89 @ Alternate)
Power Supply: Corsair RM750e (2025) 750 W Fully Modular ATX Power Supply  (€110.30 @ Amazon Deutschland)
Total: €1779.66
Generated by PCPartPicker 2025-06-30 18:29 CEST+0200
Total: €1779.66
Is that cpu cooler going to clear that RGB RAM?
Yup, I installed a TR PA120 on my rig before getting a LF3, using GSkill Trident Neo sticks, and the RGB ones aren't higher than non RGB, not like some other brands
Total: €1382,73
Thank you for all the help! 🙂
