Hi,
i would like to get your opinion on the results of my HDDs. Little Background, i recently bought 2 used 4TB drives off ebay to upgrade my Diskstation (218play) as i was running out of Space on the existing 2x 2TB Drives (Raid 1) acting mostly as a Mediaserver for my TV in the past. Now im planning to build a diy NAS with 2 Pools, 2x 4TB and 2x2 TB.
Nows the question, are these Drives still good to use?
https://linustechtips.com/topic/1614223-interpreting-smart-results/
they're starting to lose sectors.  That's the "reallocated Sectors Count" bit.
Uhhhh, why are the drives showing 0 hours?  That's not supposed to be a thing people can do to them...
There's a lot of sus going on in these pics.  I wouldn't trust em.
i have questions... how are these at zero power on hours?
reallocated sectors is never a good sign, not that it is an immediate "danger", more so a signal that things are deteriorating and you should keep an eye on it.... BUUUT... together with the clearly fudged power on hours, i wouldnt trust these.
Given the combination of the clearly modified power on hour and the reallocated sector count, I would consider returning, if possible. Some folks advise never to purchase HDDs used, but I think that's a bit strict. I would err on the side of using a reputable used vendor, such as serverpartdeals.com. (i've used this company a few times and have been very happy with their support)
ask me about my homelab
the person that sold these drives modified the drive firmware to remove the hours counters and effectively "wipe" the smart data. they usually add random data in but in this case they added random data to the re-allocated sectors which makes it show bad health. they also missed adding data in to the hours and pon count.
I would 100% not use these. not only are they old as, theyve been messed around with.
there is a bit of an art around buying used drives. it goes like this: buy bigger drives, buy ones that are guaranteed to only be a few years old because the model only just came out.
don't do it.
@ensignx
yeah those are Enterprise class drives and probably lived in a server getting the crap hammered out of them 24/7 for a few years.
What is the manufacture date on them or have the labels been messed with?
Yes, can’t trust the data you put on it, as failing sektors can corrupt data ( as you not always can read them ), and can be problematic for raid.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + Thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + PLX88024 PCIe switch (PCIE 4.0 x8 -> 4 x M.2 PCIe 4.0 x4) -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD : LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + flexiDOCK MB014SP-B + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aiyima A80 ( or Aune S6 Pro -> RCA ->  Aiyima A80 ) -> Polk S20e black -> Monoprice stand 16250
HEADPHONES : PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + Kensington VeriMark / PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Razer Wolverine V3 Tournament Edition 8K PC (B0F94C9C43) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox series x controller pc (1VA-00002) + Ravcore Javelin
NET :  Intel E810-XXVDA2 2 x 25GbE SFP28 (PCIE 4.0 x8) -> 2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3) -> Qnap TS-932X-2G + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB -> 2 x FTLX8571D3BCV-IT -> Noctua NF-P14s redux 1200 PWM -> QNAP TR-004
On 6/5/2025 at 12:35 PM, ensignx said:
Hi,
Are these new drives? check the manufacture date on them. They could still be under warranty?
https://www.seagate.com/support/warranty-and-replacements/
LOL, no, very old.
checked Seagate. no longer under warranty
Personally I wouldn't rely on SMART data, as someone alluded to; SMART can be wiped using Seagate SeaTools. Best test to see would be to write a known pattern to it and read it back.
Looks like these are drives branded with Seagate's SED, wouldn't be surprised if original customer wiped everything before off-loading.
There may be FARM log data still on the drive that has power-on hour value. Not sure if there's tools out there available that can wipe FARM logs.
rat
That was defintely done, the drive weren´t even initialised.
I now installed them in my diy NAS. Ran an long SMART Test on it (several hours), Truenas seems to see no trouble, there was no warning. The Bios has warned on Boot
Thats the result from TrueNAS, not sure what it means, but i will defintely do some writing and reading on the disks while testing.
  • 2 weeks later...
Update. downloaded seatools just out of curiosity. And surpise!
Where Crystal Disk gives a warning, the manufacture seems to be ok, with the SMART Data, all tests so far OK (long test running atm)Screenshot2025-06-19225830.thumb.jpg.3b49451e3de81c216a23572e5dc48ac9.jpg
I´ve already decided to take the risk, but instead of Mirror, i will add another used Seagete 4 TB (SMART: OK) and go RAIDZ1 on TrueNAS and having more capacity and (more important) the possibilty to add drives later (and maybe replacing the actual drives).
But i will only use them for my less important mediafiles. Using the existing 2TB Mirror on my synology for the more important personal stuff (27years of digital existence). With probably moving and or updating to the Truenas as well in the future.
That doesn't change anything… they do not want to replace the drive, why would they tell you.
The drive is in the same condition as before, I would not use it, without dual full surface delay scans ( and only if there were good I would consider it ).
EXTERNAL
HDD/SSD :
