Power supply maths help
Go to solution Solved by james8449834,
1 hour ago, brob said:
Hopefully my arithmetic is correct 🙂
Cost per Wh: £0.247 kWh / 1000 = £0.000247
Given a consistent draw from PSU of 400W @ £0.000247 Wh
Estimated from https://en.m.wikipedia.org/wiki/80_Plus 230V non redundant:
~91% efficiency with 850W 80+ Gold = ~439.56W
~93% efficiency with 1000W 80+ Platinum = ~430.11W
Difference 439.56W - 430.11 = 9.45W
Cost saving 9.45 * 0.000247 = £0.00233415 per hour
£20 cost recovered after ~8,568 hours.
Thank you that is exactly what I wanted to know, got my head around power supplies, one more thing to decide and I can order the dam thing
I'm browsing for power supply I know what wattage in need and all that good stuff.
I'm just trying to work out how long it will take to recover the extra spend if I get a more efficient,
Is there a cost per killer what how over effectively times by efficiency formula
The more efficient one is also 1000w and I only need 850w so getting the more expensive one would give me head room for upgrading so I would potentially get more use but I just want to work out the timeframe
https://linustechtips.com/topic/1614071-power-supply-maths-help/
Whats a 'killer what'?
In all seriousness, it all depends on how much you use your system, how you use your system and how much you pay for electricity.
It also depends on the price of the unit vs the other one.
Maybe you save a couple of cents a month?
Took me a second, but "kilowatt".
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
Do you run your PC under full load 24/7, running something like a distributed computing project like some of us crazy madmen do?
If yes, yes. It will be worth it.
If no, no. You won't run enough electricity to justify going from Gold to Plat / Tit.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Believe it or not, several things.
I (for the fun of it googled it and hoped for an electron with a knife) and turns out it is everything from a rock band to video games and table top games to IRL criminals has in some way been named a killer what/watt
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
what model power supply are you looking at?
What I recommend is, add up the wattage everything needs and get the next largest size of PSU for overhead when you change or add components of if you're planning on upgrading and are starting with a base system so that you heave something usable today.
For example, if everything adds up to 320 Watts get one rated at 350 Watt, there is no real benefit gained from getting anything much bigger, UNLESS the cost is the same or lower for the same or better standard rating.
I think that's a bad rule.
For example my system RTX3070(undervolted) + intel 12400 + extra = 200+70+50 W
So I buy a 350W PSU ?
I have a 550W psu (which is already considered tight) and I wouldn't feel safe with a 350W.
A 350W psu won't even be able to power my GPU, no two available 8pin pcie power connectors.
Also consider most psu efficiency curves are peaking at midload.
Edited by leclod
If you don't quote us, we won't know you answered
There are killer whales tho 😄
Back to topic, a better build PSU will also last longer
But for a given build quality buying a PSU above requirements is just a loss - but it offers possibly better upgrade path, as PSUs last for longer than core components (CPU, GPU..)
Most hobbyist desktops spend the bulk of time drawing under 20% of PSU capacity.
Unless electricity is prohibitively expensive the price premium demanded of very high efficiency PSU makes cost recovery unlikely.
Like many PC components pricing is very much reflective of demand. It's hard to find a quality PSU < 500W and units around 750W - 850W seem to have better pricing.
Thanks I'm not going to apologize for dyslexia.
But let's say for the sake of augment it's 4 hours a day and I'm doing a task the means the system is consuming a consistent 400w of power
Power supply a is an 850w gold
Power supply b is an 1000w platinum
B costs £20
And power costs £0.2470 per kWh
Absolutely not!  I have my own issues.  Just a bit of fun, dont take it too serious 🙂
B costs £20
You might make back that 20 bucks after a year or two.
B costs £20
Don't choose PSUs based on their efficiency. Choose them based on more meaningful things like their performance, noise, cables, and other nice to haves (cable pinouts, cable flexibility, lack of in cable capacitors, design etc)
Totally its creative accounting and on all honesty I had thought the there was a significant difference between the various ratings
