Hi there, this is my first post, but hopefully I explain everything enough!
So I was wondering if its possible to add a non-reference card's cooler onto a reference card. An example would be:
Bob has a reference GTX 760 pcb with a stock cooler, he would like to change this cooler for a non-reference-manufacturers-cooler (lets say gigiabyte windforce?) onto his reference card. Is this possible?
Basically I have a N770-2GD5/OC, its the crappy MSI reference pcb (bought it because it was super cheap at the time and didnt have a lot of monies), my friend has a broken gigabyte gtx 770 2gb windforce (fans work). Im looking at the pcb's and screws on both and eyeing it up it kinda looks like it'll fit but im just trying to find more pics online for the heatsink structure etc.
The reason im wondering is if i found a faulty gigabyte gtx 760 windforce online (with cooler working) just broken by some other means I guess? Is it doable?
Im not bothered about the merits/demerits of doing this, just wondered if the concept was doable!
Thanks!
PC Rig: Intel i7 4790k CPU, 2x Sapphire R9 290 Graphics, MSI Gaming 7 Z97 MB, 8GB DDR3 2133Mhz G-skill ripjaws, RAID0 2x Crucial 500GB MX500 SSD, RAID1 2x 1TB WD Black HDD, Corsair RM1000W Gold PSU, Noctua NHD14, Corsair 750D Case.
https://linustechtips.com/topic/161305-non-reference-cooler-onto-reference-card/
Unless you mount it a different way from the holes that are included, then it's just the same as installing a non reference waterblock onto a reference card. The core, memory and other chips are in different places so won't get the right contacts to the cooler as it;'s a different design.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
it depends. there are cooler that only cool the core and only use the four screws around the core. acx i believe.
I should have just used my actual scenario instead of some hypothetical one  :( .
check the PCB of your card and the PCB of the other card. put them in photoshop on 2 layers and get them together, see where it differs
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
Took a while to figure out how to chop and to find some decent images online without bothering to dismantle our own :(.
But with my extremely limited chopping skills, its a no :(
