Hello, My name is TomCasalino, and as a first time PC Builder, I would like to find a PC case that is value-oreintated (under $100), Looks nice, has a windowed side-panel, and has plenty of room for expansion. The overall budget of the pc I want to build is around $1200 - $1500, so I think that $100 will be good enough for a decent case. If you have any ideas of cases for my build, please post a comment and a link below.
https://linustechtips.com/topic/161301-help-with-choosing-a-case/
corsair 230t or nzxt h440
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
Corsair Vengeance C70
NZXT Phantom 410
Cooler Master Storm Scout
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
What form factor does the case need to be?
 Mid-sized
define r4 if it fits your build.
I was looking at that case, and if i don't find something else that i think is better, i definately will be getting it, but i am still looking for other alternatives
tower
 Mid-sized
tower
When  you say "mid size" do mean M-ATX mid size or ATX mid size?
