Help me build a PC...
Solved by NKZTO.,
2 minutes ago, Why_Me said:
Lastly to wrap things up and summarize, I just follow the rig you've given except I need to replace the GPU with whatever is cheapest between an RX 9070 XT, RTX 5070 Ti and RTX 4080 and I need to replace the power supply with the MSI MAG A850GL 850Watts PCIE5 80+ Full Modular Power Supply Gold so that the DDR4 ram sticks wont give me problems in the future and thats basically it? Again, thanks for all the help you've given, can't really thank you enough.
