i give up after 5 hours of researching
it's getting no-where so i came here to consult
i always and is on laptop, and wanted to build a desktop; heck! i even bought some parts!, but i just always ended up refunding them for no time building
and looking at the upcomming i7-4790k, it really made me wanna build a desktop for my renderings rather than using online renderings
so.....
yeah!
i'm gonna be using the EVGA Hadron hydro with custom loop because when i look at the thermal conductivity of Al, and Cu, Al is almost only half as conductive, so i wanted to custom it.
back to the problem:
i need to find a CHEAP reliable 780ti, and from what i see, the reference cards are more expensive than the custom PCB...
so far, the cheapest i see that i have heard of is GIGABYTE WINDFORCE X3 version....
can i have some help with choosing the right 780ti?
i'm actually undebuget, i need to know how much more i need
p.s. i live in england, please don't disregard the thread if you don't live in england, i really need the help
https://linustechtips.com/topic/161210-some-help-with-780ti-choosing/
Absolute cheapest one for a reliable seller (who knows about the card itself though):
http://www.overclockers.co.uk/showproduct.php?prodid=GX-055-KF&campaign=affiliate/tag
Cheapest one that I would personally recommend:
http://www.scan.co.uk/products/3gb-zotac-gtx-780-ti-overclocked-28nm-pcie-30-7000mhz-gddr5-gpu-941mhz-boost-1006mhz-cores-2880-dp-d
Both come with a free copy of Watch Dogs.
Nevermind
so.....
yeah!
£499 MSI 780ti Gaming Edition, its the card I chose for my PC, and it is quite fantastic
http://www.overclockers.co.uk/showproduct.php?prodid=GX-241-MS
