Generally speaking, yes it is
I would pay more attention on the height of the monitor (or TV) compared to your sitting position though
Gotta love your neck after all (unless you're over 190cm, which is understandable or place some distance when gaming with your cool red controller)
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
https://linustechtips.com/topic/1611238-ac-and-pc-help/#findComment-16721925
Mostly I would say it is safe.
The only thing that I think could be bad for it is if you have your PC off and the AC blowing on it cools the case/components.  Then when the AC stops the ambient air starts to condensate on the PC itself.
That is the worst case I can think of that could be an issue.  If the PC itself is on though when the AC is running, I think that would be a pretty much non-issue though as the PC likely will remain above ambient temperature.
3735928559 - Beware of the dead beef
https://linustechtips.com/topic/1611238-ac-and-pc-help/#findComment-16721933
Circulate the air in the room with the aid of a fan, if possible vent hot air from pc out of room. This will aid in reducing room hot spots and condenstation build up. If you can exchange the whole rooms air with fresh its better but in consumer sense is unrealistic. Recirculated air can lead to higher humidity levels over time. Use Dry mode on AC or a dehumidifier can also help. Stick to AC units that are non-condensing (this means it doesn't introduce moisture back into the air).
Keep the ambient relative humidity between 40% and 60% to minimize risks.
Consumer computer parts are rated for 20%–80% relative humidity non-condensing during operation.
A Hygrometers will measure humidity, Condensation sensors will measure on surface level (like a pc motherboard)
Non-condensing means the humidity isn't liquid on surfaces (moisture in the air remains vapor)
What Is "Non-Condensing"? in terms of air conditioners and PC components explained by ChatGPT
"Non-condensing" means that moisture in the air does not form into liquid water on a surface. For condensation to occur, the air's dew point must be reached. The dew point depends on the air's temperature and relative humidity:
  • High relative humidity + cooling below dew point = condensation.
  • For example, if the air is humid and cooled rapidly (like by an air conditioner), water vapor condenses into liquid water on surfaces.
In the context of electronics, "non-condensing" ensures no water droplets form on or inside sensitive components, as this could lead to corrosion, short circuits, or other damage.
Does an Air Conditioner Condense?
Yes, air conditioners (ACs) condense water as part of their cooling process:
  1. How Condensation Happens in ACs:
    • AC units work by passing warm, humid air over cold evaporator coils.
    • The cold coils cool the air below its dew point, causing water vapor in the air to condense into liquid droplets.
    • This liquid is collected in a drip tray and drained away.
  2. Air Leaving the AC:
    • The air exiting an air conditioner is cooler and less humid because moisture was removed during the cooling process.
    • However, the degree of dehumidification depends on the AC’s design and settings.
Why This Matters for Cooling Computers
While air conditioners lower humidity, they don’t remove all moisture from the air. If the cooled air comes into contact with a surface (like computer components) colder than the dew point, condensation could still form. This is particularly risky if the AC air is directed straight into the computer.
Hermit Rolling Build & Datacentre Colocation
Level 2 Support  |  Datacentre NetOps |  IT consulting  |  Entrepreneur
No help vampires, drive-by posters, or one-post wonders — I believe in mutual effort and learning.
https://linustechtips.com/topic/1611238-ac-and-pc-help/#findComment-16722017
