What can I paint, and what can I not?
リチャード
I.e
If I wanted to colour RAM sticks... if I covered the pins, could I just spray-paint it and everything'd be fine?
If I wanted to colour a fully modular PSU... if I covered the fan, the socket, the switch and all the different size pin holes... good to go?
Covering all the PCI slots and CPU socket and all the other little things etc. on a motherboard...
Covering SATA and IDE (Or whatever the other thing's called) on HDDs/SSDs... good to go?
Considering I will want to watercool the GPUs, I just get clear waterblocks and put white LEDs on.. but let's say I wanted to paint an aircooled GPU. Could I take the aircooler off and paint it white, put it back on and have everything work fine?
tl;dr : Title.
EDIT: To some people who may have seen many of my comments the last couple of days... yes, I am planning a completely white build. But not for a year. I'm just collecting some information so I can utilize it later.
I would advise against painting any PCB.
To Paint a PSU properly you'd probably want to disassemble, better off to just buy a white psu and remove the stickers.
Basically, I wouldn't recommend any of this.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
Me neither, definitely not a wise decision.
In the build log of the week, they showed someone who had painted the shroud of the sabertooth motherboard, that's one way of getting your white mobo :D
Edit: Here is the link that build log http://linustechtips.com/main/topic/12982-build-log-snefs-icy-blue-angel/
The Orange Box - Bitfenix Prodigy (Orange) / Asrock Z77E-ITX / Intel i5 2400 3.1GHz / Corsair H90 / 8GB GSkill Ripjaws 1600mhz / GTX 460 Super OC / Intel 60GB SSD / 1TB Seagate Barracuda / Seasonic G-Series 650W PSU
quick paint lesson.
paint used highly destructive chemicals to allow the pigment bond to the surface.
the chemicals if used on electronics can melt any insulation needed to protect the
circuit and first power-up all the magic smoke escapes from the PCB and it no longer
functions. no RMA will touch modified parts (painting in modifying).
in the ole days, some would paint the motherboard, some worked, some didn't.
painting the PSU is easy.. remove the metal housing around the innerds.. sand,
prep, clean, paint... let it cure and reassemble.
airdeano
That's too bad.
Brb while I write a threat to all the motherboard manufacturers about making a white mobo for Haswell.
Okay... disassemble PSU, I can do that.
What about the covers on i.e Corsair's Vengeance sticks? If I take it off and paint it on the outside it shouldn't be a problem, right?
the covers are "bonded" to the memory modules themselves. some have actually
popped the memory modules off the PCB while removing the heat spreaders.
if you mask the dawg crap out of the PCB and paint only the spreader, you should be fine.
airdeano
Why go through the hassle of painting when you can just buy white Corsair Vengeance anyway?
http://www.corsair.com/memory-by-product-family/vengeance/vengeance-low-profile-8gb-dual-channel-ddr3-memory-kit-cml8gx3m2a1600c9w.html
If you haven't already, i highly advise you to check out the guys build log I posted above, he uses all white components pretty much.
You can paint quite a bit if you know what your doing, other options would be covering (the PSU) in carbon fiber or whilte vinyl. you could also remove your motherboards heatsinks and pain those with Heat resistant pain, as for PCB's its not advisable to paint them, although im sure there are some pains that would work, they arent something you'll find in a hardware store.
Intel Core I5 3570K @ 4.2Ghz w/ Hyper 212 EVO Gigabyte Z77X-UD3H 8GB Patriot Viper 3 1600Mhz CL9 Gigabyte Windforce 3X 7950 @ 1100/1550 Samsung 830 128GB Seagate Barracuda 1TB Fractal Design ​Define R4 Seasonic M12II 750Watt
Lol, I actually googled for white memory and found 4GB sticks of Vengeance. But I wanted 8GB sticks... so thanks for that link ^_^
Mmh.. delicious information...
best way to paint a PSU is to unscrew the cover and spray it away from the inner components, paint it how you would a computer case
Character artist in the Games industry.
I've heard of people doing this, even with metallic (gold) colors.
I'd suggest doing some research on the specific paints, and know that once you paint it, it's voiding all warranties.
Not only do some paints have metal flakes, checmicals that etch, etc, but if it conducts, say goodbye to your motherboard.
Power supplies are simple. Shell it, paint, reassemble.
[TRUENO] i7 4770k (~4.4Ghz, 1.28v) || Thermalright Macho 120 || Asus Z87 Gryphon || 2x8Gb Mushkin Blackline|| Reference NVIDIA GTX770 || Corsair Neutron GTX 480GB || 2x3TB WD HDD || Corsair 350D || Corsair RM750
something i've toyed with was painting the interior of the PSU one color (accent) and
exterior another. so for an ROG build painting the interior red and exterior black. possibly
the blade assembly white. although the interior is not noticeable, it is those lil details peeps
notice and really start to look deeper into the build and finish.
airdeano
Just don't get mad :)
My father allways used to say:
"All mushrooms are eatable, but some of them only once"
Thought you might consider that, what you're planning to do requires some guts.
"Never trust anyone and rely on your instincts" - If you know who said it, you're awesome
FYI PSU!
Make sure it is unplugged and avoid touching any exposed wires or connections from the board, as this could result in one of the capacitors discharging and you getting shocked!
Lian Li PC-V359WRX Micro-ATX Case | Intel 5960X Extreme 3.00GHz | ASRock Fatal1ty X99M KILLER | Crucial 32 GB 2666 DDR4 | Thermaltake NiC C5 | EVGA Supernova 1200W P2 | 2x 240GB OCZ Radeon R7 | 2x 256 GB Samsung 840 Series Pro | 2 X 120GB Samsung 840 EVO | 6x NF-F12’s | Place Holder GPU R9 290X |
Links Current 5960X Old FX9590
Usually when I work on a motherboard I make sure to unplug it from the wall, press the power switch a few times to dump the caps, then use a big screwdriver WITH AN INSULATED HANDLE to "short" the big caps. Never have had an issue.
I'm also paranoid and leave the PSU unplugged for a few hours before I do that, too.
 You could do some thin Acrylic covers over the components u wana make white. Paint one side white and put that side down, would look kinda like the Sabertooth thermal armor but silkysmooth, And all covers/heatsinks you just remove from Component (use a good tutorial for RAM modules cause if not done right u pull the modules right of the pcb) sand down, clean with "Alcohol", primer and coats of your color of choice reassemble an d your done hehe,
Color of choice would be something that can take the heat from all the components, so like engineblock color/industrial grade paint that can take 120+ celsius.
You can wing it and paint all the Components Head on but make sure to wait wait wait for the paint to dry, hope for the best that the Color hasnt Broken anything and that it can take temps over 120+ celsius. it might go with a waterbased color with not so much chemicals but do this at your own Will and chance,
(Im not Responsible for any attempts of this if you do so) but i can tell ya this i have Painted my old P4 totally black inside with the compoments installed , didnt tape off anything just pulled 3 Cans of black engineblock spraypaint in the Case and waited for it to dry for a couple of days, its started right up and is now running in my basement as a little Home&securityServer.
But I killed my 6950 with a Black Paint Job of the Back-PCB, Did the same to my GTX 560 and it survived and is still running.
After doing som Paintjobs of heatsinks and other stuff u might get a tad worse temps on the  Components but u shouldnt and we arent talking about 10:S of Degreas just a slightly higher temps.
thats all from me, hopefully this helps a bit atleast =D.
//enRodjavel
i7 4790K@4.5GHz-1.15V, BeQuiet! SR2, Asrock z97e-itx/ac, Kingston  Fury 16GB@1866MHz, GTX 670 2GB, 3x ssdNOW300V 300ishGB, Bitfenix Prodigy, OCZ ZT 750W Twittwit@enRodjavel
You might want to look into CF Vinyl, This guy is applying it to almost his whole build, It's an awesome looking machine.
and a link to the Carbon Fiber Vinyl on 3m's website
http://www.carbonfiberfilm.com/
If painting is the easiest, then painting is what I'm going to do.
I don't really have most tools or experience with DIY. And I can't really finance both an awesome computer and experimenting with DIY. I can however, do the most easy parts just to make it look a little more clean. I might have to settle for a black/white, since 100% white realistically won't be possible. Maybe 80% White/20% Black. I originally wanted all the hardware white and with blue LEDs and watercooling a little like Snef's build. But you know... can't have it all.
I'll just take the PSU housing off when I get it, because I understand that it's like a tray with components on it, and then a housing over it. Then I'll sand the colour off of it, and re-paint it white. The inside will probably be black already.
Then I'll just buy black or white RAM sticks.
Watercooling of course will be clear blocks with white LEDs. And the coolant could be white. Pumps will probably have to be black.. I don't want to risk messing them up. I can buy white adapters and fittings etc.
I've no idea what to do about the SSDs & HDDs...
For Ssd's and Hdds the best option would be to buy a case that hides them on its own through its mounting system in which case you could paint the front part of the mounting bracket. Or to just cover it up with something like a piece of cardboard that Velcros on the HDD cage that you've painted.
I used white vinyl for my PSU, and it turned out quite well, although my standards may not be as high as yours...
"Townes van Zandt is the best songwriter in the whole world and I'll stand on Bob Dylan's coffee table in my cowboy boots and say that." - Steve Earle
